More HP !!!
Check out this thread, the same basic principles apply to any engine.
https://www.ford-trucks.com/forums/s...d.php?t=264640
For the price of the chip's right now, I'd jump on it. A chip will get you the most power, and is probably the easiest of the instalations. It's also cheaper than an exhaust, and only a little more than a good intake. An intake will get you the least noticeable gains, with all of the extra power coming at the higher RPM's where more air is required. I've done all 3, and if I had to do it over again, it would be chip first, exhaust 2nd, then an intake.
on
