Future 4.6L V8 owner
Sorry to bother you regulars here in the 4.6/5.4 forum but I am soon going to be getting rid of my 2001 4.2L V6 4x4 for a 4.6L V8.
Are there any engine problems I should be aware of on the 1998 model 4.6L 4x4.
Here is the specific one I am looking at if it interests you guys..
http://www.auto-rv.com/default.asp?a...dname=57-92736
No idea on any other things on it besides what shows on the webpage so that sucks. I am going to be calling the dealership tomorrow though. And another drawback is that this dealership is more than 250 miles away from where I live.
I'll let you know the details tomorrow.
Could I get some more information on what PI heads are? and how much power is not there? Sorry im just not an engine junkie
This motor does not have the pi heads, but that doesn't mean that it isn't built like a tank.
If you change the oil regularly the motor will run forever.
Check the transmission fluid for proper color, and proper smell. If it looks dark or smells burnt I would stay away.
The transmission fluid in these trucks needs to be changed every 25k miles with merconV and a new filter.
Other than that I would just inspect the tailgate bottom for rust, and the bottom of the doors and rocker panels.
JH
JH
Thanks for the info...
this truck has 161K!
do you still reccomend buying it??
http://www.auto-rv.com/default.asp?...adname=57-92736
or should i pay 3000 more for one that has 100k?
The PI heads have a larger, redesigned intake port and are designed to swirl the air/fuel mixture better in the cylinders. The HP went up 35 in 99. The intake manifold was also redesigned to match the heads. I believe the cams have a different profile as well.
If you could get it for 6500 or less, I'd go for it. Even if you put an engine in it later, you will still have a nice truck for under $10,000.
hey thanks alot lxman1...
You really think having a 161K engine is worth hving to worry about constant repair??
How long do these 4.6 bad boys usually last if they are treated "nice" haha....
Because If i get that truck it will be getting a lift, tires, offroadin rims....good thing to do in indiana.
you think it will last long with that kind of mods on it?
Yea I agree with you too....My dad has a 1999 F-250 Superduty 5.4L and it gets like 10-12 mpg so I'm not so sure about that. My 01 4.2L f150 gets 18 or so mpg and I love that part of my truck, I just want something that I cant put the lift and tires on and still have lotsa extra power leftover...
randomhero1172
20
04-10-2016 09:36 AM
homer4.2
Modular V8 (4.6L, 5.4L)
01-26-2005 08:12 PM
