removing paint from tire...HELP!
02-08-2002, 06:59 PM
on
Greetings, i was painting my car the other day, and accidently got some paint on the tire!!! is there anywayw to remove it??? i rotate tires so thats out of the question...any ideas would be appreciateD!
02-08-2002, 11:05 PM
Spray some WD40 on a rag & scrub it off , Just about any solvent type cleaner should remove the paint .
02-23-2002, 01:34 PM
on
Take some very fine steel wool and rub gently. Put some tire protectant on when you are done and you won't see a thing
02-23-2002, 03:21 PM
on
I use lacquer thinner when that happens. Brake fluid will also work in some cases & make your tires shine. Using brake fluid is an old show car trick used before the new tire shine stuff came out.
02-24-2002, 11:32 AM
xmontex4
1999 to 2016 Super Duty
10-31-2013 01:04 PM
99hosss
08-01-2012 07:32 AM
bigbubba87
03-12-2011 07:04 PM
96f150
Appearance & Dress-Up
06-13-2006 01:10 AM
DJ_FX
Paint & Bodywork
13
02-06-2005 10:56 PM
bronco,
car,
explorer,
ford,
ii,
paint,
remove,
removing,
show,
spary,
spray,
spraypaint,
tire,
tires,
trailer
