Header and tranny questions
Old 07-27-2004, 05:39 PM
bsour's Avatar
bsour
bsour is offline
Hello, Everybody.
I have a 1971 Ford F100 with a 360. I have already done the Edelbrock aluminum intake manifold and 4 barrel carburetor upgrades. This truck was purchased brand new by my Grandfather. Nothing major has been done to it besides minor repairs.
My problem is that my C6 transmission recently started leaking fairly bad. I am about to order the following parts from Jeg’s:
Transmission rebuild kit:
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3490&prmenbr=361
Headers:
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1281&prmenbr=361
Is this a good tranny rebuild kit? Also, will this set of headers fit? I have the cross member under the engine that may pose a problem. I thought I had read somewhere that most headers won’t fit because of the cross member.
Any comments or suggestions would be much appreciated.
Old 07-28-2004, 05:24 PM
74 F100 351m's Avatar
74 F100 351m
74 F100 351m is offline
The cross member they are talking about goes between radis arms, all you need to do is knoch it and put it back in. If you don't put it in the frame will flix at highway speed it will have slopy steering. I went though that with my 74. I put a trans pak in my c-6, works great.
Old 07-28-2004, 11:01 PM
4020loaderman's Avatar
4020loaderman
4020loaderman is offline
Thumbs up
the headers will work but will most likely need two notch about a 1/2" x 1 1/2" out of the cross member because of the collector that is what i had to my 70' F-100 with a 360 but only on the pass. side the drivers side fit perfect
Dalamatition
04-13-2004 08:14 AM
mav
Computer Chips & Tuners
02-29-2004 06:35 PM
TallPaul
Oil & Lubrication
01-01-2004 02:36 AM
Questing Beast
13
05-18-2003 08:49 AM
tapenick
Aftermarket Products
02-12-2003 08:07 PM
Quick Reply: Header and tranny questions
