Turn Signal Flasher
Turn Signal Flasher
It's under the instrument panel, near the steering column. It is cube shaped, not round like the older style.
This flasher is used for turn signals as well as flashers. Sometimes a bad bulb can act like a bad flasher. If you can hear the "click" sound, the flasher is ok. This circuit requires 2 fuses, interior fuses #21 and #22, make sure they are ok.
onriver365
01-06-2013 08:49 PM
ford1967
01-16-2004 12:46 PM
ford1967
11-03-2003 04:54 PM
