95 explorer DTC 648 - Ford Truck Enthusiasts Forums
95 explorer DTC 648
Old 07-27-2004, 03:06 PM
sbelini sbelini is offline
sbelini is starting off with a positive reputation.
95 explorer DTC 648
The OD light is flashing on my 95 explorer.
It has 171k miles on it and the tranny was rebuilt 20k miles ago (off warranty).
I got DTC 648 - incorrect gear ratio for 4th gear.
I reset the computer and the tranny shifts fine, but when its supposed to switch to the 4th gear the flashing starts.
If I reset the computer and run with the overdrive off, I don't get any flahing plus the tranny shifts smooth. Dont get the 4th gear, though (not supposed to, i guess)
I wonder if the problem could be a bad solenoid of some minor issue. Because the tranny has been rebuilt not long ago, I dont thing it would be all screwed up again. When it was rebuilt I asked the mechanic to keep the old solenoids, since the didn't read any errors and I was short on money.
I also got the following codes:
DTC 116 - Coolant temp. sender out of self-test range
DTC 167 - Insufficient Throttle Position Sensor (TPS) change during Dynamic Response Check
DTC 326 - EGR voltage lower than expected
DTC 332 - EGR valve opening not detected
DTC 335 - EGR voltage out of range
I've read in a previous forum that the TPS might be causing it (thanks to CNTHOR), so I will replace it and post the results.
Meanwhile any similar experience and possible causes / solutions is highly appreciated.
Old 07-27-2004, 03:16 PM
Sorry for the long post, but I guess any info is important :-)
Old 07-27-2004, 09:45 PM
Here's an update:
I changed the TPS, ECT, and EGR. All the codes are gone except for the DTC 648.
I guess the problem is inside the tranny, hopefully a solenoid only.
I will try changing it before I go for another rebuit. But until then I will keep driving with the OD off, since it doesnt require 4th gear (overdrive) and therefore the OD light doesnt flash.
Anyone knows where I'd get info on replacing the solenoid for the 4th gear???
Rough idle help needed wyoclint 1999 - 2003 7.3L Power Stroke Diesel 11 12-15-2016 05:02 PM
Downshift bump/clunk Ford Fx4 6.7L Power Stroke Diesel 12 02-17-2015 01:25 PM
1991 F250 DTC Problems jhartjen 1987 - 1996 F150 & Larger F-Series Trucks 0 01-17-2015 05:37 PM
2006 F150 Trans/Engine Problem Muscle Cars Blog 2004 - 2008 F150 4 07-09-2013 12:11 AM
2001 F-150 with trans DTC P1740 txspyder85 1997 - 2003 F150 2 02-26-2013 05:58 PM
Tags
116, 167, 1995, 648, 95, code, diagnostic, dtc, explorer, f150, ford, fords, obd, trouble, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
