Engine is Cutting Out/Dying('94 Explorer) - Ford Truck Enthusiasts Forums
Old 02-15-2002, 04:15 PM
Hurdle Reb Hurdle Reb is offline
Hurdle Reb is starting off with a positive reputation.
Post Engine is Cutting Out/Dying('94 Explorer)
I have a 1994 Ford Explorer (V6, 4.0L, 2WD). My Engine has been going through weekly periods where it will cut out and sometimes die...it is almost on a cycle where it is fine then it will start acting up. When it does mess up, the 'check engine' light comes on repeatedly throughout driving range... it loses all power when the accelerator is depressed, but then suddenly jumps back to normal power and does so multiple times. Occasionally, the engine fluxes while idleling, it acts as if it is gasping for fuel. Any Idea as to what may be causing this?
Old 02-15-2002, 06:03 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
The first thing I'd do is read the trouble codes from the computer, if any. If the CEL is coming on, the computer is supposed to store a trouble code. If you don't want to pay someone else to pull your codes, it's easy to do yourself with an analog voltmeter and a jumper wire.
Old 02-27-2002, 11:34 AM
sdsurf sdsurf is offline
sdsurf is starting off with a positive reputation.
I have also had this problem. I have cleaned the Mass Air Flow sensor and chenged the EGR valve, all to no avail. If anyone is familar with this problem, any help would be greatly apprecitaed.
Also I saw a code reader at autozone for $80 and was wondering if this will read stored codes or only those when the Check Engine Light is on. Please advice
-mike
Old 02-27-2002, 11:42 AM
gtyates gtyates is offline
gtyates is starting off with a positive reputation.
Sounds like it could be your fuel pump. My uncle's 94 EB was having a similar problem. He was experiencing hesitation and occassionally the truck would just die for no apparant reason. Finally, the fuel pump completely died, and after a tow, the pump was replaced and the problem solved. He was aslo seeing the Check Engine light, but no codes in the computer to lead to the problem. Hope this helps.
Old 02-27-2002, 12:41 PM
CMurph93 CMurph93 is offline
CMurph93 is starting off with a positive reputation.
i had a similar problem with my 93. it turned out it was a faulty connection from the battery to the fuse box. I had the same problems with loosing sudden power and then getting it back, however mine got so bad that everytime i hit a pothole the car would stall...it was a very loose connection. My suggestion would be to try and tighten that up and see if the problem persists.
Old 02-27-2002, 03:01 PM
Haven't had any problems with it dying and it has been like this for quite some time so I don't think it is fuel. Is there a check you know of? I also heard it could be the fuel pressure regulator. My leanings are more toward emissions and intake, o2, egr and what not... any other hints?
Old 02-27-2002, 03:02 PM
I checked all of the wiring and just had neg of battery off last night. Seems that all the connections are fine, i am stumped. ANyone out there with help?
Old 02-27-2002, 05:54 PM
benhj benhj is offline
benhj is starting off with a positive reputation.
2002 Explorer shuts off on it's ownThrott Eric3501 Explorer, Sport Trac, Mountaineer & Aviator 16 06-06-2016 11:15 AM
Truck is sputtering and won't accelerate Willow1013 Modular V8 (4.6L, 5.4L) 4 02-26-2016 09:39 AM
Throttle issues 2000 F350 Beachdvm 1999 - 2003 7.3L Power Stroke Diesel 2 12-12-2014 12:52 PM
Engine Cutting Out cbshaffer Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-22-2013 05:48 PM
Apparant Engine Cutout fbavaro1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 03-19-2011 07:41 AM
Tags
40, 93, 94, acting, air, cuts, dying, engine, explorer, f150, flow, ford, idleling, mass, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
