Ford ranger 2.5L hard start when cold - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-27-2004, 06:37 AM
brug79 brug79 is offline
brug79 is starting off with a positive reputation.
I have a 99 ford ranger with the 2.5L engine. The truck is difficult to start when it sits over night. The truck will start and the abruptly stall. I have gotten the truck to run by giving it gas and running it about 1500 rpm. The truck is perfectly fine after about 2-3 minutes of doing this. The truck will idle normally after this 2-3 minute period. Once the truck is warmed up you can shut it off drive it and it dosen't stall after its warmed up. The truck can sit for a couple of hours and start back up perfectly. The problem does not happen every morning though. The truck has 50000 miles on it. The check engine light does not come on when it is hard starting or at any other time. I put new plugs and wires on the truck after it started having this problem. This still did not help the problem. Please help
Thanks
Adam
Old 07-27-2004, 08:04 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Pull the codes, there may be a 'pending' problem. CHeck the ECT & ACT sensors. The ACT is Air Charge Temp, so if it thought the air was warm coming in, it would not do the high idle & richen functions.. Same for ECT, engine coolant temp. These function to let the ECM know that you need bumped idle & slightly richer fuel mix.
If you are not even getting a bumped idle, when you used to, I'd be checking the ECT more than ACT, but it could be the IAC-Idle Air Control, too.
tom
Old 07-27-2004, 07:28 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
I would also check fuel pressure at cold start.
Truck Stalls When Warm 1987 F-150 1987 - 1996 F150 & Larger F-Series Trucks 5 06-04-2013 09:23 AM
HELP with 2006 F-250 6.0 BarterOnlycom 6.0L Power Stroke Diesel 24 04-26-2013 08:33 PM
Ranger 2.9 Running rich, stalling and roaming idle santeeford Ranger & B-Series 2 11-06-2010 07:58 PM
Truck vibrates/shakes after start up MTENIENTE 4 Cylinder Engines 9 12-07-2005 08:31 AM
Ranger with Mustang engine, stalling RangerToMustang 4 Cylinder Engines 2 10-23-2004 04:14 AM
Tags
2000, 25, 25l, 87, 89, 99, cold, ford, hard, ranger, sensor, sitting, start, starting, struggles, wranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
