If the system is generally in good shape, you are usually better off having a shop leak check it and drop some R12 in it. Its a more efficient refrigerant, and unless there is a system failure I see no reason to convert it to the less efficient R134.
__________________
Boeing 747-400,
Early '99 F350 4x4 std. cab PSD.
Mods: Clamp. That's all at the moment.
When I die, I hope to die as my grandmother did; peacefully in my sleep. Not panic-stricken, screaming in terror like the rest of the people in her car.
