Rear Axle Endplay
At least some of the end play comes from the clutches in the Traction-Lok assembly wearing out. Assuming you have a TL rear (all AWD vans do), you might check to see if the diff is still locking: Jack up just one side of the rear, and try to turn the wheel. Ford specs about 40 lb-ft of break-away torque.
There is nothing that solidly holds the axle shafts into the housing. On the inner end, the cross shaft of the diff carrier form the inner limit for the motion of the axles, and the C-clip (horseshoe clip) pushing against the clutch pack and side gears form the outer limits. As the clutches wear, there is more slop for the axle shafts to move in and out on.
Originally Posted by copper_90680
My 2WD doesn't have traction lock, but it still has end plays.
pineconeford
09-04-2016 04:29 PM
IntheTrees
08-04-2009 07:19 AM
captcalvo
02-12-2003 10:54 AM
Eddie
02-12-2001 03:15 PM
