Rear Axle Interchange - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-26-2004, 04:41 AM
83Van's Avatar
83Van 83Van is offline
83Van is starting off with a positive reputation.
Question Rear Axle Interchange
My '83 E100 van came with a code "14" rear axle which I see listed as a 3.00 ratio, and I need to up this to at least a 3.55 for towing. My rear end is a 9", but most of the suitable donors I've found at the local salvage yard are later models with the 8.8" rear end. What year/ model 8.8" will bolt up in place of the 9"? I've been told most vans made up till '91 would have the same shock mount locations, etc, anyone know if this is correct?
Second option is to keep my rear end and swap out the 3rd member from another 9" with the appropriate gearset already in place [if I can find one]. Would this be easier than swapping out the whole rear end?
Old 07-26-2004, 08:00 AM
86rustbucket's Avatar
86rustbucket 86rustbucket is offline
86rustbucket is starting off with a positive reputation.
I'm pretty sure that the chassis up to 91 were the same, so the 8.8 should bolt right in, I would just check the spring mounting pad width and u-joint type. The driveshaft length may vary slightly also due to diff size.
My suggestion would be to look for a new 3rd member, maybe lower gears. There are a few companies (Jeff's Bronco Graveyard) that make rebuilt 3rd members for the 9", but they are kind of pricey. You could probably find one used if you look hard enough.
Or, just buy some gears and have a drivetrain shop swap them out, or do it yourself.
Old 07-26-2004, 12:05 PM
blue_mule's Avatar
blue_mule blue_mule is offline
blue_mule is starting off with a positive reputation.
keep the 9 .... it is better than the 8.8. Build a the 3rd member and put the gears you want in it.
Old 07-26-2004, 08:14 PM
83Van's Avatar
Big thing here is a combo of time and $$. Would prefer to find a 3rd member w/ appropriate gears to swap out as this would be the easiest overall swap, but finding a 9" with a decent ratio has proven a bit tough. If I had a wad of cash just I'd buy a new ring & pinion and have it installed. Unfortunately that's not the case.
Old 07-28-2004, 02:29 AM
abn abn is offline
abn is starting off with a positive reputation.
You can set ebay up to email you whenever a new item in your keyword search turns up...I've seen plenty of complete 9" centers show up there ready to go. 3.55:1 is pretty popular, I can't see you waiting over a couple of months to find one that ends under $300.
Old 07-28-2004, 04:28 PM
83Van's Avatar
Not going to "ebay" a pumpkin, shipping would eat you alive. My local pick-ur-part lot sells pumpkins for ~$49, complete rear ends for ~$59. If I were going to do the eBay thing would just get a gearset and pay a local shop to set it up.
Old 07-28-2004, 08:47 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
It's worth $500 to get one that doesn't whine....you'll really hear it in a van.
Not to mention clunk etc. Lots of places selling 9"ers.
I bought one from a 4x4 outfit that claimed to be "The Ford 9 Inch Experts"
After 5 diffs, I got one that was acceptable.
Ask about their guarantee......
Old 07-28-2004, 09:58 PM
abn abn is offline
Yeah, shipping is a &$^$(, I spent $110 on shipping for the rear end I bought (full rear with axles though)...I wouldn't have done it except for the 31 Spline Torsen differential and nodular case that attracted me. There is a serious pucker factor when your waiting to see if you got junk or not when the price gets up there. I even live close to a pick-a-part, but I've just been getting used to parts showing up on my doorstep. For some reason my pick-a-part doesn't seem to have many 9" rears anymore. They must get picked through during the week.
Old 07-28-2004, 11:07 PM
83Van's Avatar
About half the 9 inchers in trucks and vans are either stripped of their pumpkin or in some state of disassembly, most of the intact ones are 3.0 or 2.75 [no one wants 'em]. If a 3.50 9" doesn't turn up in the next week I'll probably do the rear end swap for one of the early 90's 8.8's which are plentiful.
Old 07-29-2004, 12:59 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Check the racing sites for a new gearset. Some places have them pretty reasonable.
Body Plate Decode - 1964 Econoline Pickup ApocBane Ranchero & 1961 - 1967 Econoline 1 09-06-2013 06:39 PM
Ford 8.8 Front and Rear axle set BlueOvalBud Offroad & 4x4 1 01-22-2013 08:28 AM
Swaping out ford 9'' rear end for 8.8 Loud4.9 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 02-21-2010 09:09 AM
8.8 vs. 9 inch. 84tealbeast 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-14-2006 03:20 PM
Rear Disc Swap from 2000 8.8" Rear to a 73 shortbed1 Clutch, Transmission, Differential, Axle & Transfer Case 1 05-16-2003 09:33 PM
Tags
88, axle, ford, inch, interchange
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
