Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-25-2004, 11:51 PM
pinhead is starting off with a positive reputation.
360 or 390
i just pulled my 360 out of my 60 f-100 4x4 . it had 3 bent push rod's .i am going to do a complete rebuild on it but need to know : do i build it back as 360 or 390???????? any help on cam type, crank ,pistons would be appreicated!!!!!!!!!!
  #2 (permalink)
Old 07-26-2004, 11:08 AM
Mike G is starting off with a positive reputation.
Check out the FE forum, plenty of info there, other than that, all you need is crank/rods/pistons from a 390 and you conversion will be complete...
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #3 (permalink)
Old 07-29-2004, 12:01 AM
tude is starting off with a positive reputation.
ive heard that the stroke of a 390 rod (longer ) and the stroke of a 360(shorter) the pistons would hit the bottom of the heads
make sure if you use all 390 parts turn the moter over by hand to see if the pistons will not come out of the block
  #4 (permalink)
Old 07-29-2004, 10:31 AM
Actaully, the rods on the 390 are shorter than that of the 360. You would want to use the 390 rods just for the fact they have more beef on them and will hold up better under heavy use.
--Mike
__________________
Mike G
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
  #5 (permalink)
Old 08-02-2004, 03:36 PM
MontanaFord is starting off with a positive reputation.
from what i'm told...and take this as it is, hear-say...the 390 will get better mileage and give you better performance than a 360 will...just something to think about...i don't know the truth behind it, but that's what i've been told...
MontanaFord
__________________
1992 F-150: X-cab, short bed, 300-6, 5 spd manual, 114000 miles at time of purchase...gonna git shined up nice...
1982 Full-size Bronco: 300-6, 4 spd manual, 9" rear...gonna git some mods done soon...
Member: High Plains Drifters
  #6 (permalink)
Old 08-03-2004, 01:52 PM
Azguy54 is starting off with a positive reputation.
I am in the process of doing just that, rebuilding a 360 and going to a 390 with it. You can use the old 360 pistons IF they are slipper skirt units, not full skirt. Actualy the compression height is better on the 360 pistons, at least in my case. Unfortunately I could not use the pistons over due to wear so I went out and got some Speed Pro hypereutectic units. P/N H305P.
Hopefully will have the rods resized by this weekend so I can start the build.
__________________
George
'68 F100
'01 F150
'97 Aerostar
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
