I want to locate the lines that go from the tranny to the radiator to cool the oil off. There are several lines coming and going from the radiator. Which one are the transmission's lines? How can I identify them? any special color?
My ride: 1995 EB Explorer.
I don't know if yours would be the same as my 1992 Explorer, but the tranny lines run into the left side of the rad. There are two flare nuts that fit to the plastic tank. About 3/8" dia lines.
Hi, Crawl under the truck at the passengers door area. Look for two metal lines / tubing 5/16" - 3/8" diameter coming out of the tranny, follow these up to the radiator.
