65 F250 conversion to disc brakes - Ford Truck Enthusiasts Forums
Old 07-25-2004, 07:26 PM
scmagner scmagner is offline
scmagner is starting off with a positive reputation.
Unhappy 65 F250 conversion to disc brakes
So I read every single tech article on the web about this brake swap and talk to every ford person I know and decide that this is a doable albeit trying swap that will make my truck safer and easier to work on. (Once the swap is done and all I have to do is replace pads and turn rotors as needed). First problem king pins in a 65 f250 are more like tooth pics compared to 79 f250.(King pins almost fell out of both spindles just a regular hammer and good drift this was way over-hyped if any maintence has been done on either truck) Big problem spindles will not work. The spindle swap is out so now i have to change whole front end suspension. Next problem about an inch too long (a problem I would like to have) with 1/2 inch longer in the I beam and 1/2 inch in the rotor assembly. Can I drill another hole in the bracket that the I beam sits in move it back 1 inch? I have read that almost everyone has this same problem with the swap (which is why I wanted to swap the spindles only). May be the bracket off of a 79 will work or is the frame 1 inch wider in a 79. Any help from someone that has been through this would be great.
Old 07-25-2004, 08:08 PM
hawkrod hawkrod is offline
hawkrod is starting off with a positive reputation.
I have never had the trouble you are experiencing but i hear tell there are actually two different sets of front disc brakes for an F250 in the 70's based on axle rating. they are both 8 lug but one is based on F350 parts and the other is based on F100 parts. my bet is you have the heavier duty brakes. though i have never actually looked into this to verify it, the spindle and kingpin seem to be the difference between the two sizes of axle ratings with the smaller one having a smaller kingpin like an F100. perhaps you could spend a little time at a wrecker with a few trucks and see if you can find another set of brakes with the smaller kingpin size? hawkrod
Old 07-25-2004, 10:01 PM
I would really rather use these heavier duty parts with the duel caliper discs because I already paid $200 dollars for them and I intend to pull a bobcat skidloader and some very heavy loads up and down hills etc. Is the inch longer going to be a problem or can I make these work with no modifications. I have read about the extra inch on many conversions so I do not think that would change even with the f100 parts.
Old 07-25-2004, 10:04 PM
the brakes are not different from what i understand, it is the hub and spindle. they all use the big rotor and 4 piston caliper if i am not mistaken. hawkrod
Old 07-25-2004, 10:19 PM
I measured the I beams as well as the spindle and hub assembly and have about 1/2 inch difference in both of them making up the inch longer in length. If I bolt these up will my wheels be to far out and come in contact with my fenders and if so is there any modifications I can do to make these fit. Like drilling a new hole one inch farther out to bolt up the I beams to or a wheel that will fit these brakes and make up the 1 inch difference (changing the center of the wheel in closer to rotors to clear the fender.
Old 07-25-2004, 11:55 PM
6t6merc 6t6merc is offline
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
I attempted to install rebuilt beams/spindles from a '78 F250 with the hd 1.06" kingpin. The rotor/hub unit which mates to this (larger) spindle uses larger bearings than the .875" pin F250 item. I believe these rotor/hub units are otherwise dimensionally identical, but have one other major difference - the larger uses a 9/16" wheel stud, the smaller uses a 1/2". They both (my trucks, at least) use a 2-piston caliper.
I was not aware that the disc brake axle assembly is 1/2" longer. I would like to hear more about this.
Eric
Old 07-26-2004, 05:14 AM
oldtrapper oldtrapper is offline
oldtrapper is starting off with a positive reputation.
Hawkrod
I agree with your call on 2 different calipers. I have my dad"s 73 f250 and when picked up new pads I found out there were 3 different gvw ratings for that year and we had the 8600 gvw version and the pads were much bigger and beefier than the single piston and much more expensive. I just swapped a 79 f150 6900 gvw susension complete front end in a 66 w/no problem even though the new one is wider than the 66. I be leary of redrilling the axle holes. FWIW
OldTrapper
Old 07-26-2004, 01:27 PM
I am going to try the swap with the beefier I beams, calipers, spindles and wheels studs since my purpose for this truck is work. I still have two questions where and how much were the rebuilt I beams or did you mean salvaged and did this make the swap easier? Also what about steering linkage did your old linkage fit the new spindle or did you upgrade a 73-79 linkage.
F250 versus F350 2wd wheel bearings Harkijr 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-13-2015 04:19 PM
Brake Questions, and F100 Vs. F250 ? BigB9000 1967 - 1972 F-100 & Larger F-Series Trucks 4 08-27-2015 08:01 AM
Lowering a 81 f-100 Gary Cosby 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 07-13-2014 10:33 AM
One more disc brake swap question....... tinman52 1961 - 1966 F-100 & Larger F-Series Trucks 6 01-22-2014 05:35 PM
King Pin Removal, Trouble...That was Way too Easy reamer 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-31-2005 09:28 AM
Tags
250, 65, brake, conversion, disc, f250, pickup, spindles, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
