How to check if alternator works...?
Take your voltmeter and hook it to the battery with it off. Should be about 12.4 volts, give or take a couple tenths. Start the engine and rev it. Then check the voltage. Should be around 13.6. If it does, then the alternator should be OK. As far as your running problem I would look at the TPS or fuel pressure and regulator.
Originally Posted by f1001978
You should never do that, it can cause huge voltage spikes and fry your computer. You could do that to the old generator systems but not an alternator.
Alternators are still generators - they need 12v to generate the moving electrical field that induces current in the stator coils. And removing a battery cable when the engine is running can generate a huge voltage spike in an internally regulated system. It's even worse if the battery is partially discharged - the alternator is already working overtime, and suddenly all that energy has nowhere to go. We're not busting your chops here, but there are much more reliable and accurate ways to test an alternator. A 15 dollar analog voltmeter should be in every Bronco owner's toolbox!
To answer Muddweiser, I would have the battery charged and tested out of the vehicle, by someone with a resistance or "load" tester. If the voltage readings don't register 13-14v with a freshly charged battery and the vehicle running, then remove the alternator and have it bench tested. Always make sure a new alternator has a freshly charged battery to work with. If you have access, the alternator can be "full fielded" while on the vehicle, and this will rule out a faulty voltage regulator. Honestly though, a bench test at Napa or Autozone will give you more useful information.
I agree with that. The best way is to take it off and have it bench tested. Some are eve able to put loads on. I was just stateing that you could test them that way, I should have noted though that it is NOT advisable on newer vehicles with the computer controls. My oops.
And yes I know your not trying to bust my chops and niether am I but I disagree with the statement that alternators are still generators, there is a big differance.
