Rear window washer not working
Old 07-25-2004, 02:17 PM
kgolden's Avatar
kgolden
kgolden is offline
I noticed water running out of my excursion behind the right front wheel. Started after toping off washer fluid. Now my rear washer doesn't work. Anyone else have this problem? Can your give guidance on the fix? I have not looked into it at all and hoping to take the path of least ressistance (lazy). Any help appreciated.
Old 07-27-2004, 11:44 AM
kenw's Avatar
kenw
kenw is offline
I had the same thing happen to my 2001. It was under factory warranty so I had the dealer fix it. Turned out to simply be the hose feeding the rear wiper came off a fitting. Since the dealer fixed it I can't provide details or tell you how hard it is to reach the fitting. Hopefully this helps you in the right direction anyway.
Old 07-27-2004, 01:04 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
water out of the right wheel well may be just A/C condensation and just coincedental with the wiper washer stopping....
OR it could be a loose hose....
have someone try the rear wiper while you look in that area...
(engine off of course!)
Sorry - it will take some effort and proably a ladder to see into that tall engine compartment
Old 07-28-2004, 02:39 PM
kgolden's Avatar
kgolden
kgolden is offline
The guy who services my rig said he has several excursion with this same problem. It probably is just the hose. I will check it this weekend and post my finding. I am also installing my lift this weekend, very excited!!!
Ex03AK
10-12-2022 04:25 PM
altascene
1997-2006 Expedition & Navigator
11-10-2016 09:05 PM
AVR2
Escape & Escape Hybrid
04-29-2016 08:37 PM
NDL
1983 - 2012 Ranger & B-Series
04-20-2016 07:59 PM
Quick Reply: Rear window washer not working
