Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-25-2004, 11:21 AM
Roamer is starting off with a positive reputation.
Fan switch connector - Where can I get one?
I had the fun joy of ripping my dash apart yesterday. Yup, the usual diverter door hinge repair/replacement. Thankfully, with help from this forum,that job went super easy and my door is now swinging supper easy on a nice, nickel piano hinge.
My repair job was a bit bigger than most: last winter, my A/C control switch broke. On my 81, this is the vacuum control switch that sets all the doors in the ducting to get heat/defrost/AC/etc. It is kind of a pancake. The bottom of the switch has a ratchet assemble that gives you the detents at the various positions. It has a pin that hangs down and engages the lever that you actually move. On top of this switch is the part that actually operates the vacuum "stuff" as well as turning the blower off or tuning it on high. It connects to the ratchet part with a pin that engages it. That little connector pin broke on my truck. Thankfully, it looks like a bit of epoxy, fiberglas fibers and an old sheet metal screw have repaired this item back to 100%!
Now for the only remaining issue: the connecter on the left side of the heater control module controls the fan speed. When I removed this connector, it broke into a million peices. It looks like it had overheated (BADLY) and was super brittle. Has anyone seen this before? Does anyone know were I can get a replacement connector shell? The pins look good so I would hate to have to splice into my wiring harness to replace the shell. Also, can someone post the wire color codes and their locations in the connector?
Thanks for the help!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
