Ok, starting to gather parts for the infimus SAS. I want to get some extended radius arms, that are releaved for bigger tires like the james duff radius arms. The two things I don't like about the ones from james duff are the price, and well, the price. I'm going to do some wheelin, but not an awful lot. The only real thing I want them for is so that my tires don't rub like mad. Does anyone else make these? Also. If I buy the 9" for the 79- F150's, will it lift mine 11"? If It only lifted it 9, would I have to fab up some drop down brackets for the radius arms? Any imput is appreciated. Thanks guys,
~Kevin
hey I bought the ones from james duff they are not bad but yes they are pricey i have almost 20 inches of lift and i had to cut the drop bracketes and make them sit lower and they will make the front sit 2 to 3 inches higher
the arms are about 12'' longer than stock and yes they have the bend to clear the tires although it looks to me that anything over a 35 or 37 inch tire would still rub some . i can take pics just let me know from what angle or which part you would like to see.
thanks jopey are them stock radius arm boxed with some dom tube welded to them. and 514 if u can take a pic where i can see how it mounts and one with the tires cut one how the mount to the frame and take one of the hole truck so i can see how far they hang down. i think i may just make my own like fabtechs.tanks to the both of ya
they are boxed with 1/4" plate on both sides. the DOM is 2" x .25" I also welded some nuts on the end of the threads then proceeded to also weld thos nuts on the inside of the DOM. nothing like welding down a tube with a stick welder. Then I welded in some inserts for the Heims.
hmm im thinkin of makin me some. would u happen to knw if u could bend the arm so bigger tires clear. cause with 35s i hit the stock ones eazy.also do u know what size nuts u used the nuts on my arms now are big.
what ever nuts fit in the DOM and over the radius arm threads.
I have 39.5's with 3.5" back spacing on my rims and they barely touch the radius arms when turning. You need to get some rims that push the wheels out from the axle. Stock rims will rub with 32's
Here are the pics of my radius arms with modifications to drop bracets. I needed to do this because of the amount of lift,(20inches). If you need other pics i would be glad to get more. https://www.ford-trucks.com/user_gal...toid=63037&jpg
Reason: Remove [img]
