Any resolution to the AC problems??
Has anyone went to direct to Ford about the AC, did they do anything? MIne has right at 3000 miles on it and the AC sucks. Have it full blast on max ac and it never gets cold enough to turn down like normal pickups. Took to shop 1 time and they say it is fine. Bull poop!! I will probally sell if they dont fix
edited for language..........if it trips the language filter please hit the edit button and try again.
Take it back to a different dealer. I had this problem and they reflashed the PCM for incorrect outside temp reading and replace a controller nozzle. AC works great now and can freeze you out of the cab. If you do a search for "AC not blowing cold" you should be able to find the TSB number. Ford is well aware of this issue.
