Steering wheel vibration in F-150
Old 07-24-2004, 10:03 AM
GLakes's Avatar
GLakes
GLakes is offline
I recently purchased a 2004 Ford F-150 Supercrew and I had a vibration in the steering wheel when go it up to speeds between 70-75 mph. I took it back to the dealership and they rebalanced the tires, but it still has slight vibration. I also had a road force balance vibration done and their is still a vibration as well as more road sensitivity feel in the steering. Has any one else experienced this problem and did they have success in figuring out how to fix it.
Thanks
Old 07-24-2004, 04:39 PM
JohnAndHisDog's Avatar
JohnAndHisDog
JohnAndHisDog is offline
Go to Search at the top of the board; then Advanced Search; then type in nibble for the search word and select the 2004 Ford section. You'll find a wealth of information.
Here's a popular thread to get you started.
https://www.ford-trucks.com/forums/s...d.php?t=234453
Old 07-24-2004, 08:37 PM
boss351cj's Avatar
boss351cj
boss351cj is offline
Hi-
Tell your service dept. to cut to the chase , adjust the preload on the rack and pinion steering. Most of them have hardly any preload , and they finally listened to me two weeks ago- Tightened it up , and the wheel is rock solid at 70-75 mph. Never so smooth - Try it!
I went through all the rest first with no luck -(tires, balance,rack replacement, re-balance, alignments, driveshaft repl.,etc)
Old 07-25-2004, 12:56 AM
akford150's Avatar
akford150
akford150 is offline
I mentioned this procedure to my Service manager the last time I briught my truck in and he told me the rack could not not be adjusted with another preload setting. He said the rack needed to be replaced if they thought it was faulty.
It make sense to me, if the pre-load is very loose very little road fault will be felt through the wheel. I have printed this and will show my service manager.
Dhudec
2017+ Super Duty
35
02-02-2018 09:13 AM
William Martinez
02-23-2017 11:22 AM
roholendt
1997 - 2003 F150
06-02-2016 05:26 PM
96F250FL
Offroad & 4x4
02-25-2015 12:50 AM
ford8n47
1999 to 2016 Super Duty
15
11-12-2006 06:00 PM
Quick Reply: Steering wheel vibration in F-150
