97 Explorer code P0446 - Ford Truck Enthusiasts Forums
Old 04-02-2002, 06:36 PM
Sid06 Sid06 is offline
Sid06 is starting off with a positive reputation.
Post 97 Explorer code P0446
mil light on and code P0446 cannister vent mafunction any ideas.
Old 04-03-2002, 12:17 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Did you refuel while the engine was running or forget to replace the gas cap & start the engine ?
Old 04-03-2002, 09:25 AM
No it started out as an intermitent problem but now it stays on all the time. I can clear the code and it will come back on somewhere around 150-200 miles. I searched the nhtsa site for TSB and found 1 #BC0312970501. The last time I had it at the dealer the lite went out before I got there and they said there were no hard codes and I haven't had a chance to get it back yet.
Old 04-03-2002, 10:55 AM
Ok , Which engine does your Explorer have , Etc ?
Old 04-03-2002, 11:10 AM
5.0 Liter Auto AWD
Old 04-03-2002, 11:29 PM
It may be the gas cap is leaking , faulty . Also check the fuel filler pipe , it may be venting some pressure due to a clamp being loose etc . Check all the Evap Emission hoses as well .
Old 04-08-2002, 11:55 AM
I inspected the gas cap and all the emmision lines from front to back.
I decided the valve on the vapor canister was stuck open the vapor canister is located on the frame in the rear mounted above the spare tire and gets alot of dirt and grime from the road thrown up on it. I have driven it several miles and every thing seems to be working no codes yet. Thanks for your help.
Phillip Fell
Old 04-08-2002, 12:57 PM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to behold
still getting p0446 code Villengineer 1999 to 2016 Super Duty 5 09-30-2014 03:53 PM
Keep getting P0446 code. joshco 2004 - 2008 F150 2 01-15-2014 08:23 PM
P0446 Diesel_Brad Ranger & B-Series 37 08-02-2013 04:18 AM
Dtc P0446 rangerguy52 Explorer, Sport Trac, Mountaineer & Aviator 1 01-29-2006 12:18 PM
Code P0446 jp756 Explorer, Sport Trac, Mountaineer & Aviator 3 06-10-2004 07:22 AM
Tags
08, 1996, 1997, 2004, 2005, 2006, code, e250, engine, explorer, f150, ford, mountaineer, p0446, po446
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
