Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-22-2004, 10:54 PM
uponyou21 is starting off with a positive reputation.
Question Clunking Noise???
Just thought i give it shot here I've had my lift in my truck since april (6"inch all spring lift) but i noticed the last few days there is a clunking noise whenever i go to take off or when i go from like drive to reverse also when i go to stop sounds like it is coming from the rear. I think what it is the axle is twisting because the springs are starting to break in might need traction bars anyone have any ideas???thanx
__________________
2003 F-350 XLT Sport 6.0L C/C,
List Mod's In Your Gallery
FTE
  #2 (permalink)
Old 07-22-2004, 11:11 PM
cali1911 is starting off with a positive reputation.
Smile
Springs typically need more time than a few months to break in. Unless you've been hitting the trails pretty hard or towing some serious weight. Psd and 6 inch lift is a no brainer for ladder bars/traction bars. However, check every nut and bolt on the rear end to make sure something isn't coming loose. Check shocks mounts, "u" bolts etc.. I've got 11" of lift and I need traction bars but i don't hear clunking, just creaking. Clunking is not good but more than likely it's something very simple. Just keep checking it out and be careful. I like to crawl around under the truck when i hear a noise and just investigate. Always better to be safe than sorry, goodluck. Richard
P.S. nice looking truck I looked at your pics.
  #3 (permalink)
Old 07-22-2004, 11:30 PM
Aarkie is starting off with a positive reputation.
If you are running a two piece drive shaft it could be the spline where they fit together. If it does not have grease it will bind then let loose with a clunk. Set the brake or block the wheels, mark the drive shaft, drop it, take it apaart and grease the spline, put it back together, and reinstall. The boot has a compression cramped ring that is hard to get back tight if you do not have the crampers for it, but can be done.
__________________
99 F-250 SD, extended cab, powerstroke, gauges, 4" exhaust, Predator, AIS intake with mod.
97 F-250 LD, extended cab, 5.4, no mods.
  #4 (permalink)
Old 07-23-2004, 12:39 AM
All true! I think? check everything.
  #5 (permalink)
Old 07-23-2004, 08:22 AM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE. npccpartsman is gaining momentum as a positive member of FTE.
My ex-boss had this same problem with his 99 after a few miles it clunked and clunked. The dealership rebuilt the rearend twice--checked every bolt and nut and never could find the problem. Took it to another dealership on the FIRST dealership's recommendation and they found it in less than 10 minutes--seems the "BIG" dealership didn't know about greasing the driveshaft splines either. It is the easiest place and probably the most overlooked to start. You'll know immediately if it's the problem!!
  #6 (permalink)
Old 07-23-2004, 09:16 AM
I had to do mine. If you search the 7.3 forum you will find more information on greasing the shaft and more information on how to do it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
