Tailgate bedliner screws...Now what? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-22-2004, 09:49 PM
huntercgr's Avatar
huntercgr huntercgr is offline
huntercgr is starting off with a positive reputation.
I took off my bedliner from the tailgate, and put the screws back in. It seems they are too long now. Are shorter ones available from Ford? I was going to get it sprayed tomorrow with Line-X.
Old 07-22-2004, 10:00 PM
Pocket Pocket is offline
Pocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputation
Or just go to Home Depot/Lowes and find what you need. That would be much faster and I'd bet cheaper too.
Old 07-22-2004, 10:03 PM
FordxFour FordxFour is online now
FordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to behold
When they put my bedliner in they used the factory screws, they were plenty long enough. Don't know why someone would change the screws unless the tailgate liner is alot thicker than the ones I've seen.
Old 07-22-2004, 10:30 PM
daimon1054's Avatar
daimon1054 daimon1054 is offline
daimon1054 is new and has a neutral reputation at this point.
If your going to get it sprayed the holes will get filled in so you should not have any problems.
Old 07-22-2004, 10:58 PM
jhemr's Avatar
jhemr jhemr is offline
jhemr is starting off with a positive reputation.
They make two different screws for the tailgate, one with a shoulder on it
for the liner and one without the shoulder to use without the liner.
I changed mine when I took the liner off also. If I still have the Ford part
number for them I'll post it here.
Old 07-22-2004, 10:59 PM
Greg250 Greg250 is offline
Greg250 is starting off with a positive reputation.
A factory Ford tailgate liner needs the longer screws....I know...I did mine myself. Unless you like having 1 or 2 out of 6 threads catching...you need the longer screws.
Old 07-22-2004, 11:01 PM
BTW...you have to put the old screws back in otherwise the cover on the tailgate will fall off
Old 07-22-2004, 11:06 PM
daimon1054's Avatar
I just caught that I though he had holes in the gate where he screwed the liner in.
OK if they are long you can buy new ones or just cut them down, thread a nut on and hacksaw them or grind them back the nut off and your set.
Old 07-22-2004, 11:39 PM
huntercgr's Avatar
Sorry guys, I should have stated I took OFF the dealer installed drop in liner. I think JHEMR has it correct, I need new, shorter screws.
Old 07-23-2004, 06:33 PM
4x4x4x4 4x4x4x4 is offline
4x4x4x4 is starting off with a positive reputation.
A word of caution...When you install new screws don't use a power tool.Use a drop or two of blue loctite and don't tighten very tight.I have seen what dealers do to the screw holes and it isn't pretty.
Old 07-23-2004, 09:57 PM
jhemr's Avatar
Quote:
Found the Ford part number for the bolts "N806149 S301"
The liner on the tailgate is held on with 8 longer bolts that have
a short unthreaded section (shoulder) up by the head, these also
help hold on the access cover on the inside of the tailgate, there are 10
screws total that hold this cover on. The part number above will match
the two that are under the liner. This is what I did to mine and yes I
went to Ford to get the screws, they were about 80 each, but they
all match and you can't tell there was ever a liner on the tailgate.
Hope this helps.... Joe
Old 07-25-2004, 10:44 PM
huntercgr's Avatar
Thanks a ton Joe. Got it sprayed and I haven't been around to drive to a dealer yet but will do so this week.
Tail gate Machman Ford Truck Parts for Sale 0 05-01-2016 07:04 PM
Rust and bedliner LRMetric 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-17-2012 06:23 PM
Tailgate Step Delete sgrol 6.7L Power Stroke Diesel 12 06-18-2012 03:29 AM
Stupid Bedliner 19expy97 2004 - 2008 F150 18 03-25-2008 11:22 PM
Can't open Tailgate... neon4x 1987 - 1996 F150 & Larger F-Series Trucks 4 01-20-2008 10:28 PM
Tags
1999, 2002, bed, bedliner, bolt, f250, ford, liner, n806149, screws, shoulder, superduty, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
