Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-21-2004, 08:28 PM
CathyT CathyT is offline
Garage is empty, add now
CathyT is starting off with a positive reputation.
Wink Idling high in Neutral
Dealership could not fix problem....so I'm turning to all of you! When I let off the throttle, put manual trans. into N, the engine still rev's at around 2.5-3k RPM's for about 5 seconds and then notches it way down to normal. It will go from 3 to 1.5k then to normal idle. The RPMs go to a "normal" speed when engaged in a gear. For instance, when driving and changing from 2nd to 3rd gear, when depressing the clutch the Tachometer does not fall for the second it takes to change gears, it stays rev'ed, then once the clutch is released and the gear is engaged ,the RPM's are appropriate for the speed and gear.
The IAC valve was changed but this did not fix the problem . Do you think it could be the Throttle Position Sensor? It has been hot outside the AC was on initally but then shut it off and the problem still existed. The engine did not rev in the morning...it was much cooler. Thanks in advance
  #2 (permalink)
Old 07-22-2004, 09:40 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Nice problem statement.
But. Need to know the year and engine/trans you are running. The IAC controls the idle on a MAP system, but an air leak elsewhere from the IAC will allow for a high idle. On MAF systems, extra 'unknown to the MAF' air will cause a poor idle and hesitation, for instance . If you have ODB-II, you can read the commands to the IAC to know if the ECM is telling it to keep the idle up. I'd check for codes to make sure that the hi idle isn't trying to compensate for some other item that is malfunctioning.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 07-22-2004, 11:34 AM
uh oh...it's a 6 cylinder...
see you in 3.0L V6 thread....I'll continue there
Tags
high, idling, neutral, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
