Error code 341
Error code 341
My Haynes manual describes the code as "Octane adjust service pin OPEN". The code is only detected during a Key on, engine off test.
I think I have seen this on the wiring harness in the general area of the self test connector leads. On my 91, it is a grey plug, plugged into a wiring harness connector. The wiring diagram shows a shorting bar on a lead from the ECM to the EDIS module (lead color PINK?). I think it is used to slightly advance the timing a few degrees when removed, when higher octane gasolines are used. Do you notice any pinging or do you use higher octane than regular unleaded in the vehicle?
I you really want to clear it, look for a wire plug with 2 leads inside that is missing a shorting plug, then go to the junk yard and get one to fill the hole.
Dialtone
Dialtone
gesb123
1999 to 2016 Super Duty
10-29-2014 08:46 AM
CNTHOR
08-24-2002 07:50 PM
