I want to change diff cover to increase the amount of fluid for cooler running when I tow. Does anybody make a steel unit. I don't like the aluminum covers because they are expensive and if you hit something with them aluminum will tend to crack where as steel will tend to bend so you won't loose your fluid. Any thoughts??
