Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-20-2004, 09:59 PM
evil64 is starting off with a positive reputation.
C-6 Trouble
My tranny dosent engage unless I put it in first gear and give it some gas. If I just put it in drive it will just sit there like its in nuetral. Any thoughts? Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-20-2004, 10:03 PM
KwikFord is starting off with a positive reputation.
Check your fluid level first.
  #3 (permalink)
Old 07-21-2004, 09:58 AM
mark a. is gaining momentum as a positive member of FTE.
Maby something in the valve body.
  #4 (permalink)
Old 07-21-2004, 10:21 AM
hdgapeach is starting off with a positive reputation.
Fluid level first. Fluid and filter change after that. While you have the pan off for the filter change, you might as well remove the valve body and give it a good cleaning and air check. Adjust the band to specs. Do a vacuume check on the modulator valve and check the vacuum hose that is connected to it (all of it, from the valve to the engine). When all the general maintenance is completed, if you still have the same problems, repost for more possibilities.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
