Diesel on the Dyno?
I didn't take your stance as either hostile or combative.
and he's got a formula for converting hp to torque
in the start of this thread you guys were looking for a tach. signal. i read in another thread that there is a clean tach signal bundled with those"courtesy wires"under the dash, that ford runs through the fire wall. the other post said it was the pink wire under the dash with the other wires and it was put there to help with installing a remote start...dont know, but it might be worth checking out.
divit250r said: Wouldn't you be able to reconfigure your formula and come up with the calculation for TQ from HP?
Torque x RPM / 5252 = HP
HP x 5252 / RPM = Torque
Using the B-D formula, and my crude formula, all the trucks in the test group had resultant answers within a few ft/lb, regardless of mods, etc.
One variable that wasn't included in the test group was a truck with a different turbo housing. The power curve is steeper in the midrange for a truck with a 1.0AR housing, so the crude formula wouldn't be as accurate for my truck as it sits now.
All this is assuming that the formula that Brian gave me was accurate for Powerstrokes. At least it gives you someplace to start.
I hope you find this somewhat useful.
Back to the tach wire, I pulled mine from the block of wires under the hood, its a big block looking thing on the drivers side valve cover. I believe the wire is kind of goldish/yellow. Truck is at my friend house now, i can look tomorrow and give an exact #, or at least be more specific.
I PERSONALLY OWN A DYNOJET DYNO. It is a mobile chassis dyno. The way you get a tac reading off of a diesel motor is to place a peice of reflective tape on the harmonic balancer. You then place a pickup sensor that looks at the balancer and every time the motor tunrs over it reads it. The pickup plugs into the computer, if your speed shop has the pickup that is. Any questions go to www.dynotex.net or call me at 940 - 902 - 3445. I will be happy to answer any dyno questions. Bryce.
Will a 172" wheelbase fit on the mobile dyno? I know a guy up in Springfield MO. that has one, he's pretty sure my truck won't fit.
