HELP! need location of fuel pump reset button - Ford Truck Enthusiasts Forums
Old 05-16-2002, 05:26 PM
Tyger9791 Tyger9791 is offline
Tyger9791 is starting off with a positive reputation.
i removed the battery cables from the battery to try and
clean out the corrosion off the terminals. not after replacing the cables, the truck will not start. i did not realize or know that the explorer has the fuel pump shut off switch. i do not have an owner's manual because i bought it used. I NEED to know where this is located in a 1996 ford explorer or any ford explorer (i assume they wouldnt move that around on the newer ones). PLEASE HELP!
Tyger9791
'96 Ford Explorer XLT "Tonka Truck"
Old 05-16-2002, 06:33 PM
CNTHOR CNTHOR is offline
CNTHOR is starting off with a positive reputation.
The switch on my '95 is on the firewall inside the cabin near the front passengers foot area
Old 05-16-2002, 07:32 PM
Thank you. i found it. unfortunately still no go. battery is not charging up enough for engine to turn over. i think i just may have a dead battery. the positive cable was very corroded and the positive terminal and end of the cable are melted. the bolt is stripped as well, making it nearly impossible to get on and off. sooo i guess i'll be going to autozone tomorrow to get a new cable and check out my battery. maybe hopefully i'll find out what caused this, it was not like this yesterday. all of a sudden, on my way home from work, check engine light came on and truck got real sluggish. and now here i am. sigh.
Tyger9791
Old 05-17-2002, 09:18 AM
winfordr's Avatar
winfordr winfordr is offline
winfordr is starting off with a positive reputation.
T-18 transmission problem ktm4012 Clutch, Transmission, Differential, Axle & Transfer Case 4 03-13-2016 03:13 AM
type of oil pan for 351w in 87' bronco? BRONCINATOR 1978 - 1996 Big Bronco 2 02-25-2005 06:19 PM
Headlight switch tyger25 1997-2006 Expedition & Navigator 1 09-17-2004 12:04 PM
Traction bars.... tyger25 1997-2006 Expedition & Navigator 3 07-09-2003 01:17 PM
Subwoofer Mystery Revealed!!! tyger25 1997-2006 Expedition & Navigator 0 04-22-2003 08:36 PM
Tags
1997, 96, connect, explorer, f150, f350, ford, fuel, location, pump, reset, shut, sport, switch, trac, transit, v8, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
