York Compressor Fittings...Need Help
I have a 75 F-100 with factory a/c. When I got the truck I was told the compressor was bad and so...not knowing any better, I threw it away. My probelm is that those fittings (discharge and suction) that were on that compressor fit the a/c lines that are left in the truck. I went to a junk yard and and pulled another york comp, but the fittings on top of the compressor don't match up with the lines in my truck. My truck has the screw on fittings on the lines. I need fittings that mount to the compressor with a two-bolt flange type and have threads to receive the existing lines. Where can I find the right compressor fittings? Thanks. By the way...I already tried the junkyard.
__________________
Michael
