Dual fuel tankS
The way this system works is the pressure from the low pressure pump that is turned on by the switch on the dash cause the selector valve to move to the tank whos low pressure pump is running. When the slector starts doing what yours is doing there is no fix accept to replace the selector. it is fairly simple to bypass the selector valve. I took 2 fuel filters and cut the quick connect ends off and brazed them onto 2 pieces of steel tubing long enough to bridge the gap between the selector and the fuel line going to the high pressure pump and the return line. I used discarded fuel filters for my donors
That's another good idea but don't forget the size of fuel line fitting aren't the same for pressure and return lines.
Looking for third 3rd fuel pumps ?
The way this fuel system works is the pressure from the low pressure pump that is turned on by the switch on the dash cause the selector valve to move to the tank whos low pressure pump is running. When the slector starts doing what yours is doing there is no fix accept to replace the selector. it is fairly simple to bypass the selector valve. I took 2 fuel filters and cut the quick connect ends off and brazed them onto 2 pieces of steel tubing long enough to bridge the gap between the selector and the fuel line going to the high pressure pump and the return line. I used discarded fuel filters for my donors
Thanks Kwikford for the pic of the the selector valve, thats what i have.
Originally Posted by mike L
Thanks Wtroger, do you have an 87 ford f150 4.9 liter? I'm looking for a third fuel pump? It looks like i have two interneal fuel pumps.
3rd pump are located on driver side frame approx 7 inches in front of selector valve.
pm me for your email addy so I can take picture of 3rd pump.
I found the electric fuel pump! Its between the fuel filter and selector valve. Does that mean that i can try to bi- pass the selector valve? The parts store said to use hose clamps and brass fittings. What's the best way to repair fuel lines? What should i use to fix a leaking fuel tank?
Kwikford, I looking under Galleries whats the Album name your using? Is your truck a 4X2 or 4X4? Thanks again
"High Roller"
https://www.ford-trucks.com/user_gal...&albumid=11177
this truck originally came with 2 wheel drive. I bought it on Jan 10 2004. Few months later I convert to 4x4.
Wtroger , I disconnected my fuel lines a my front fuel pump and the fuel is coming out of the return line. Are the return lines 3/8"? I think my fuel filter ends are 5/16". How did you find a second fuel filter with 3/8" ends? The return line has a push-connect fitting at the fuel pump. Do you think i should bi-pass the selector valve or block off the fuel lines at the fuel pump. I was wounder how long before my selector valve stops working completly. Thanks guys
Possibly Safety Recall 93S68
Ford calls the problem "fuel cross-flow" and there was safety recall 93S68 dated late 1993 that addressed that problem on my 1990 F350. I just checked my truck records to verify numbers. Ford extended warranty on mine for 150k miles or 12 years. Problem was in the fuel pump/sender assembly.
ray
ray
ray
ray
That's a totally different recall! That's not related to Mike L's problem.
#28
#29
Recall fuel tank selector valve
Originally Posted by KwikFord
I did a couple search high and low.
here's what I found.
scroll down and you can see the selector valve clearly.
http://bjoern.brembs.net/cars/FordPU.html
TSB / recall 91s39 <<< I'm guessing on this since I can't access to alldata at this moment.
#30
Kwikford I looked up all the years for recalls on the selector valve and the only year i found was for 1989, 91s39 issued in 1991. The only difference was it was for a 4X4, mine is a 2X4. Is the fuel system on a 1987 F150 4.9 2X2 the same as a 1989 f150 4.9 4X4? The selector valve pic above is the same as mine. Also can this recall only be good under a 3 year warranty, thats what ford told me today.
yes, Fuel system from 4x2 and 4x4 are the same.
I didn't know it is 3 year warranty. My apologies.
