Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-18-2004, 08:03 PM
Scott_McGee16 is starting off with a positive reputation.
67-72 360cid rebuild
I have found a 67-72 360cid engine that I would like to rebuild, but I need some help. First of all I am replacing a 302 - so the mounts wont fit will they?
Secondly is there much for preformance parts for this size of an engine? I want a good 350 hp out of her. What can the bottom end on these engines handle?(stock) and what can they be built to handle? Thanks.
  #2 (permalink)
Old 07-18-2004, 09:55 PM
fordeverpower's Avatar
fordeverpower is starting off with a positive reputation.
A fe crank is good for 600hp and 6000 to 7000 rpm. You want 350hp, get a edelbrock rpm intake, edelbrock heads, headers, crane 901 cam, and a holley 4bbl. It will cost you but it will scream.
__________________
Matt
79 f150 390 4x4 c6 RIP
78 F100 390 2wd c6
78 F150 351m 4x4 c6
  #3 (permalink)
Old 07-19-2004, 12:24 AM
Wow, thats an impressive crank- can the pistions and connecting rods keep up?
Are the FE's a 4 bolt main or just 2 bolt?
  #4 (permalink)
Old 07-19-2004, 12:55 AM
i wouldn't try the rods and pistons to that level. Most all fe are 2 bolt main. All 360 would be. And weather you know or not a 390 crank swaps in that block. The difference is that you need the 390 rod which is a tad smaller and a 390 pistons. The 360 pistons have the same bore but each fe piston has a different compression height which would change compression ratio and or hit the head.
__________________
Matt
78 F100 390 2wd c6
78 F150 351m 4x4 c6
  #5 (permalink)
Old 07-19-2004, 10:48 AM
Mike G is starting off with a positive reputation.
You can find any truck from 65-79 that had a FE engine in it and use the motor stands/mounts. You will also need a different tranny coming from that 302.
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #6 (permalink)
Old 07-22-2004, 12:34 AM
so what you are saying is I could turn the 360 into a 390 if I am rebuilding the bottom end entirely...?
Would the heads swap over as well?
  #7 (permalink)
Old 07-22-2004, 10:12 AM
You need the 390 crank/rods/pistons, and the rest of the goodies from your 360 will work... Heads are all the same, intake can and should be upgraded to a 4brl (even a stock cast one will work).
--Mike
__________________
Mike G
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
