Reverse Lamps kit
Reverse Lamps kit
"Hi" has any of you fellow F-150 owners seen a kit on a truck accessory web site for fitting extra reverse lamps. I live in England and have seen this kit where you mount a bracket down by the tow hitch and then fit these two small lamp units either side of the hitch. The reason for this is over here we have to have orange indicators which flash independantly rather than being coupled to the stop lamps. So i have to do away with the reverse lamps in the rear lamp clusters and convert these to indicators by fitting orange bulbs. It works ok and makes the vehicle legal for me to drive on the English roads. If any of you has seen these kits on a web site please give me a clue. Oh my truck is an 04 Lariat Screw in wedgewood blue fully loaded, it's awsome.
Regards V8.
Regards V8.
Dang, didnt kno y'all were allowed real cars over there. Best bet is to check out JC whitney at www.JCW.com . Any light setup will work if you tap it into the trailer wiring.
Thanks for that address i just looked and yes they are on the site. We do have quite a few trucks over here now, i had to get this one from Canada as no dealer would play ball but i had to go round the back door to get this one. I've had so many extras fitted all i need now is a bigger garage to put it in. Once again thanks for replying so quickly, regards V8
greystreak92
1978 - 1996 Big Bronco
17
03-27-2012 07:53 PM
ctubutis
Electrical Systems/Wiring
05-28-2010 06:16 PM
Spark-e3
10-22-2005 04:39 PM
