Smokey, smokey--'88,7.3,F250,5spd,Biodiesel
I am quickly becoming an urban menace. My truck's MO, for the last 20,000 mi or so, has been to smoke at idle when cold and then clear up. recently the cold idle smoke has increased by a large factor (but still mostly dissapears when warm) and...it has begun to smoke whenever I release the accelerator while still leaving the clutch engaged (pretty much in any gear at any speed, warm or cold). No smoke uphill or at high speeds, only when I start to slow down. I am guessing the injector pump is to blame. Just adjustment or is it trash? Note: this truck has been running on biodiesel for about 2 and a half years (40-50,000 mi).
Also...who makes the best Maint/Tech manual for the 7.3l of an '88 variety?
Cheers
Cheers
If it was water wouldn't I notice some loss of fluid in the radiator? I haven't lost even the smallest amount.
I think that it is fuel as my truck, being bio-d, is pretty ripe and, having been engulfed in it on a number of occasions (picture putting your head over the stove vent of a cheap chinese restaurant) the smoke seems to clearly be smoke. Maybe I am overestimating my ability to tell...
I had an injector shop tell me the IP would need to be replaced for a similar problem. He said the advance mechanism wasn't working correctly. I asked him how that was effecting the operation. He asked if I was seeing white smoke at startup, then it goes away. This is what I was seeing. He also said if I didn't mind the little puff of smoke, not to worry about it for now, but eventually I would need to replace the IP. Since I'm still getting better than 18mpg around town, I'm not going to touch it!
Brent
Brent
"Perhaps being bio, it smokes different too. I guess more diagnosis will be needed to help determine. I am planning on trying straight wvo, so I have some to learn on this..."
I use biodiesel in my '93 F-250. It doesn't smoke. Biodiesel won't by itself cause smoke. On the contrary, it cuts soot by 90%.
I also use a wvo/diesel blend. Don't bother trying wvo to cure the smoke.
#1. Can only use <=50% wvo in a stock, unheated fuel system.
#2. Has similar smoke production of biodiesel, ie, very little soot.
