Water/Meth Injection - Ford Truck Enthusiasts Forums
Old 07-17-2004, 04:25 PM
xlrs xlrs is offline
xlrs is starting off with a positive reputation.
Hello All,
I have a early 99 7.3 SD. I've been looking at water/meth injection kit from Dieselsite. Is there anyone that could give some feedback on how they like their system and any pros and cons.
Any info would be greatly appreciated.
Thanks
XLRS
Old 07-17-2004, 04:27 PM
HeatStroked's Avatar
HeatStroked HeatStroked is offline
HeatStroked is gaining momentum as a positive member of FTE.HeatStroked is gaining momentum as a positive member of FTE.
Cookie88 has recently installed the water/meth injection system. Send him an e-mail with your questions.............
Old 07-17-2004, 06:13 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
I love water injection. Other than the initial cost the power is practically free. The main reason I bought it was for the lower EGT's, but the power it add's is a nice kick in the pants too. I have yet to experience any downsides. I suppose since water doesn't compress that one could get into trouble injecting too much water at too low boost pressure, but I start the first stage at 15 psi boost with 130 psi pump pressure and it works great.
I don't know anything about the snow performance system that dieselsite sells. My DPS system has a reservoir that is at least four times the size of the snow kit, my pump looks bigger...hard to tell from the picture, and my system uses all heavy duty weatherpack switches and connectors (similar to OEM) with braided steel pressure lines. IMO it is a superior system.
http://www.dps-performance.com/
Old 07-17-2004, 06:34 PM
Sounds great. Now the wallet gets a little thinner.
Thanks guys!!!
XLRS
Old 07-18-2004, 01:17 AM
BBBxcursion BBBxcursion is offline
BBBxcursion is starting off with a positive reputation.
I used the DPS system and I LOVE it!
Old 07-18-2004, 08:30 AM
How difficult are these systems to install?
XLRS
Old 07-18-2004, 01:27 PM
took maybe 1 1/2- 2 hours
Old 07-18-2004, 01:54 PM
Thanks BBBxcursion
Old 07-18-2004, 08:56 PM
cookie88's Avatar
It took me quite a bit longer than that. Since I have a six speed I could not use the suggested mounting location under the hood, nor could I route the wiring through the firewall as easily.
Old 07-21-2004, 05:47 PM
joes96300i6 joes96300i6 is offline
joes96300i6 is starting off with a positive reputation.
Does anyone know of a website that sells water injection kits? And does anyone know any "for-sure" performance numbers on what it will do to an engine, paticularly the 4.9?
Old 07-21-2004, 05:54 PM
Look at the third post on this thread.
Old 07-21-2004, 10:57 PM
cookie88's Avatar
Quote:
I've seen a mixture of 15% meth mixture make 50 horsepower on a turbocharged 6.9, thats what sold me on the kit. The website I posted claims a 40-90 HP improvement for the PSD based on the % meth used and injection pressure. I have not put mine back on the rollers with the water, but the claim is easily believeable for me.
Old 07-21-2004, 11:14 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
Former Vendor
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
Guys, find the Water/Methanol Injection thread in the 6.0 area, get a cup of coffee and read through it. You will learn ALOT. Its over 800 posts long.
Both I and BigHoss550 are already running the system (Mine from DPS and his homemade) and Choctaw Bob is in the process of installing his.
Old 07-23-2004, 01:44 PM
I hate to be repeative but, what i want to know is will water injection help my nearly stock 96 4.9. I just want something that will add a quick boost to help blow the 4 banger rice burners away. BTW my only current "performance" upgrades are KnN air filter, and a single in single out flowmaster.
Old 07-24-2004, 11:12 PM
cookie88's Avatar
Water injection on a N/A straight six??? Risky. Powerstrokes really don't care for the water below about 15 psi boost. I would think with zero boost the water might just put out the fire. Then there's a risk of timing/detonation issues, and or just blowing the thing up froma hydro-lock.
IMO it would just be easier to slap a 50-75HP nitrous oxide shot on it and call it good.
schematic for MAF speakerfritz Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 7 12-02-2015 08:35 AM
schematic for MAF connector needed speakerfritz 1999 to 2016 Super Duty 1 11-19-2015 02:39 PM
Alcohol Injection Systems 91 Dually 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-30-2013 10:58 PM
water-meth injection chevskeezy 1999 - 2003 7.3L Power Stroke Diesel 8 03-15-2006 01:33 AM
Garage/Shop xlrs Utah Chapter 3 10-31-2005 07:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
