Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-16-2004, 12:05 PM
Ssqtch Ssqtch is offline
Garage is empty, add now
Ssqtch is starting off with a positive reputation.
Thumbs up BioDiesel
I found this article on MSN's site.
http://autos.msn.com/volvo/article.a...tentid=4022450
Anyone know about using it in the 6.0L PSD?
-Brian
__________________
'04 F-350 Lariat Crew Cab FX4, PSMoonroof, PS Rear Window, 6.0L PSD, Dark Shadow Gray Metallic'95 Grand Marquis 140k miles
  #2 (permalink)
Old 07-16-2004, 12:11 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
I older trucks you can't run pure biodiesel because it is incompatable with rubber. Newer vehicles, however, can run on B100 with no problems. Let's keep in mind though that biodiesel and vegetable oil are not exactly the same thing. If you want to run straight vegetable oil you would need to modify your engine. I also would not recommend doing this because most of the research that I've seen shows that it is very hard on the injection system.
You can certianly run B20 with no problems (as shown in the picture from your link). From what I've heard, most people report that their engine runs smoother and quieter on biodiesel.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
  #3 (permalink)
Old 07-16-2004, 12:51 PM
Twin Tritons's Avatar
Twin Tritons Twin Tritons is offline
Twin Tritons is starting off with a positive reputation.
Here's a pretty good article on making your own bio-diesel from waste vegetable oil. Make your own bio-diesel
Sounds like a lot of work, but also states that you could make it yourself for less than $0.75 per gallon. Would also mean you would have to round up large quantities of used vegetable oil.
__________________
2008 F-450 King Ranch CC, LB, DRW, 4x4, 6.4 PowerStroke, Auto, 4.30
2010 F-150 Raptor 4x4, 6.2L
  #4 (permalink)
Old 07-16-2004, 01:56 PM
mattsf250 mattsf250 is offline
mattsf250 is starting off with a positive reputation.
Quote:
and you would need to dispose of ALOT of waste that was not useable. sounds like a total waste of time, not to mention, dealing with methanol.
__________________
'06 SCab FX4
  #5 (permalink)
Old 07-16-2004, 02:05 PM
wolffee's Avatar
wolffee wolffee is offline
2004 Ford F-350
wolffee is starting off with a positive reputation.
it sounds like a really cool idea and i read alot about it at other sites and i bet if i had like acres and acres of land i could set up a shed and get like a 1000 gallon tank and do it like out in the back in a shed or somthing like that and make it in bulk but i live in a residential area i dont think i should be messing with methanol and all in large enough quantities to make it worth it in my garage. and then storing it in there that is a problom just waiting to happen.also i mean i use alot of fuel i think i mean about 29 gallon every 4 days at like 450 a tank i would want to make like 1000 gallon or more at a time or your going to be making it like every few days and who wants to do that?. its just not ready yet i think to be making it at home even if it does average out to .75$ a gallon. just my few cents
__________________
2004 F-350 King Ranch 4x4 6.0 SRW SWB CC.
2.5in Leaf Spring Lift in Front.5in blocks in rear. Moto Metal 20x10's 295 65R20 Nitto Terra's. 4in stright pipe turbo back, 5in Tip. Femco Oil Drain Valve. SCT Tunner. Train Horns. Upgraded Compressors and big tank to run air tools. CB Radio. Bilstein Shocks. Amsoil Oil ByPass System. Coolant Filter ByPass.
  #6 (permalink)
Old 07-16-2004, 03:37 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud of
Wolffee - not being mean or anything....
but please allow me to take a breath every once in a while!
when I read that without any breaks I get outta breath :-)
__________________
13 F-350 Platinum 6.7 CC SB Tuxedo Black Metallic 11.5k gvwr,
13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost Tuxedo Black Metallic.
12 MVP Destiny 355RE 5th wheel
gone-12 F-250 6.7 CC SB Sterling Grey Metallic Lariat w/ Ultimate Pkg. MBRP filter back Exhaust, Airlift air bags.gone-05 Ex 4x4 6L,even goner-2002 4x2 7.3L Ex Limited
  #7 (permalink)
Old 07-16-2004, 03:47 PM
SBV45's Avatar
SBV45 SBV45 is offline
2009 Ford Explorer
SBV45 is starting off with a positive reputation.
He's got a period in there somewhere.
__________________
2009 Explorer Eddie Bauer 4.0 V6 4X4.
Previous:
2005 Nissan Xterra 4X4
2003 Ford F250 6.0 Powerstroke 4X4
1986 Ford Bronco 4X4
  #8 (permalink)
Old 07-16-2004, 04:46 PM
wolffee's Avatar
2004 Ford F-350
haha sorry about that i thought i had one in there somwhere. i never was good at grammer i will try to slow it down. i just get going you know. hard to slow it down. heres a couple of the periods i forgot to put in. not quite sure where they go though haha ...........................
__________________
  #9 (permalink)
Old 07-17-2004, 03:52 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
Here is Ford's broadcast message to all dealers regarding Bio-Diesel:
Ford's Position on Biodiesel:
Ford is advising that any of their vehicles powered by a diesel engine, regardless of manufacturer, may exhibit engine or fuel system problems when using fuels with greater than 5% Biodiesel. Any problems when using fuels containing more than 5% Biodiesel should be referred to the fuel manufacturer. Ford only recomends using fuels containing no more than 5% Biodiesel (B5) in their diesel powered vehicles. In addition, as per World Wide Fuel Charter (WWFC) catagory 1-3, fatty acid methyl esters (FAME) must meet EN14214 and ASTM D 6751 specifications. Broadcast Message 0884.
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #10 (permalink)
Old 07-17-2004, 03:54 PM
Ford is obviously covering themselves to avoid warranty work. If you plan on running biodiesel higher than 5% I guess you're on your own.
__________________
173K miles
CMP Info1
CMP Info2
  #11 (permalink)
Old 07-17-2004, 05:17 PM
SBV45's Avatar
2009 Ford Explorer
I understand that biodiesel's chemical make up is higher in some acids. Thsi could be the reason for the Ford disclaimer. I would hate to booger up (technical term) my injectors.
__________________
Previous:
  #12 (permalink)
Old 07-17-2004, 06:31 PM
Got Diesel?
Don't quite understand why people buy a new $40,000+ truck and then want to modify it, inject it with water, run unapproved, use bio-diesel and do other things on a truck with a warranty???
Why not buy a used truck with whatever mileage and modify it all you want. One it less expensive and two, you don't have to worry about fighting Ford over your warranty.
Personally, I would NOT run bio-diesel until it is widely available and has been approved. I'll wait for the diesel-electric motor like they use in locamotive engines if I want power and mileage. This could/would be the equivalant to the gas/electric cars from Toyota, Honda and others????
Thanks... just my .05 cents worth (which is more than others .02 cents)
Jeff
__________________
24" Wiper Blades
  #13 (permalink)
Old 07-18-2004, 07:00 AM
Ahh, thank you, I knew somebody here would know Ford's official stance on it. This is my first Diesel truck, so I'd never really looked at Biodiesel before.
__________________
  #14 (permalink)
Old 07-19-2004, 11:37 PM
OMCUSNR OMCUSNR is offline
OMCUSNR is new and has a neutral reputation at this point.
Ford is just covering their ### with that statement. So do VW, GM, & DCB. I run bio in my truck w/ no problems whatsoever. Their are a couple hundrerd thousand europeans running bio diesel in their vehicles w/out problems too.
The auto manufacture's can't control what you put in your vehicle, and they try to limit their liabilty by making statements like that. They can't control the quality of either gas or diesel or natural gas or biodiesel.
Commercial grade biodiesel is better for the truck (lubricity), better for the environment, better for the econonmy & the country. There can be enough feed stock for the oil available w/out drastically increasing farm land.
As far as I'm concerend, if Rudolf Diesel & Henry Ford thought vegitable oils should power their machines, who am I to argue?
__________________
Mar 03 Silver F-250 SD, SC, XLT, Fx4, 6.0L w/ 3.73 LS 6-spd ZF
  #15 (permalink)
Old 07-20-2004, 05:51 AM
SBV45's Avatar
2009 Ford Explorer
Quote:
Here is Ford's position on biodiesel in a service message:
__________________
Previous:
Tags
2004, biodesiel, biodiesel, f350, ford, offical, position
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
