Explorer with leak in head gasket, anyone ever use K&W block seal? - Ford Truck Enthusiasts Forums
Old 06-14-2002, 03:58 PM
1991Explorer 1991Explorer is offline
1991Explorer is starting off with a positive reputation.
My 1991 Explorer has been losing antifreeze for quite some time. It was a fairly slow leak and the third time I had it pressure tested they discovered a leaking head gasket. The good news is it isn't leaking into the cylinder but out the back of the head. Since the engine has 220k on it I don't think it's worthwhile to have it torn down to replace the gasket. If I have the heads redone I'm sure the rings will go. Has anyone out there ever used K&W block seal? Did it work for you or cause problems? According to the directions the system needs to have just water in it, run for 20 minutes with the block seal, drained and allowed to sit for 24 hours. Then flush with water and fill with anitfreeze. The radiator and heater core are both less than a year old. The only ingredient listed is in the warning label which say's that it contains Sodium Silicates. I don't plan on getting rid of the truck as it still looks and runs good. Thanks in advance to all who reply.
Old 06-15-2002, 02:06 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
If I was keeping it I would take it apart and do it right!
A true Ford Guy wouldn't do the wrong thing keep this baby looking nice
and running great.
Just my .o2
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls offrd snowplow pkg Trueblue/Silver Two Toned and Chrome nerfs
No mods needed its "Kuel-E-nough for Me!"
Old 06-17-2002, 02:09 AM
samhihn samhihn is offline
samhihn is starting off with a positive reputation.
If you're planning on keeping the truck and you've got the time, go ahead and replace the head gaskets. Just read and follow the label directions! Don't re-use the old head bolts! It won't cause the rings to go bad! If you just need to do a temporary fix to get you by for a while, the K&W block seal is a good product. It could hold you over for a pretty good while, but you have to "read and follow the label directions" or it won't work. Then, when you get a chance, go ahead and change the gaskets. It can be done with the engine in the truck.The felpro gasket"set" will come with all the gaskets you need.Good luck
Old 06-17-2002, 02:37 PM
1fast68 1fast68 is offline
1fast68 is starting off with a positive reputation.
New truck and engine build DarkStarMedia 6.0L Power Stroke Diesel 12 11-24-2016 12:03 AM
Has anyone used to product K-Seal to fix myutesux Ford Inline Six, 200, 250, 4.9L / 300 3 07-22-2015 11:01 AM
5.0 Cam Swap Help? 68horses Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-16-2015 08:21 PM
5.0 Cam Swap Assistance? 68horses Explorer, Sport Trac, Mountaineer & Aviator 0 06-15-2015 04:41 PM
Coolant Entering Cylinders? - Already Replaced Head Gaskets Sprucegreen 1997-2006 Expedition & Navigator 8 06-05-2015 09:28 AM
Tags
1991, block, directions, engine, explorer, gasket, head, instructions, k7w, kw, review, seal, sealant, sealer, silicate, sodium
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
