Twin Tritons-
Here is what I found out from my friend so far. Yes, Ford does have a marine version of the 7.3PSD, he was not sure about the 6.0PSD. The 7.3PSD marine version was rated at (330 hp) vs. 235 for the light duty truck application (If you are framilar with marine engines the higher horespower ratings of marine vs. car/truck are typical). For information on ford's marine engines he recommended contacting Ford's industrial and marine engine division, FPP or Ford Power Products.
www.fordpowerproducts.com. They should be able to assist you with any information, and questions regarding the 6.0PSD.
He mentioned many other diesel marine options are available for leisure/sport marine applications. Here are some he mentioned:
Do I dare say it? Cummins has a marine version of the 5.9 available in 305-350hp applications.
Perkins - Some of the lower displacment CAT engines are made by Perkins and marketed as a CAT.
Lugger/Northern Lights
Yanmar
Volvo penta - equipped with there own volvo jet drive. (Volvo really does make some neat marine engines. Many of the lower displacment diesel application utilize a forced air (supercharing) in conjunction with turbo. The supercharger kicks in at low rpms, and lets off when the turbo has started to spool up. - Very nice and no lag when trying to get a boat up on step (not really a problem with the low draft of a jet though).
International also markets a small 150hp version diesel that is utilized in jet applications. I believe he said it was the HS 2.8L.
Hope this information helps out. If you have anymore questions please let me know. While my knowledge is limited, this friend of mine is very knowledgable and talented indivdual). In addition to repowering his Uniflight by himself. He designed and fabricated his own jet boat (19' aluminum powered by a 350 Mercrusier and Hamilton jet) 9 years ago. I guess that's what being an excellent aluminum welder, mechanic, and holding two degrees in engineering does for you.
Please let me know if you need any more information.
