400 build-up
Old 08-15-2004, 10:32 PM
ford5.8's Avatar
ford5.8
ford5.8 is offline
400 build-up
I'm going to build up a 400 possibly with cleveland heads or have a 429 balanced and blueprinted..
What motor would be better for it?
It pretty much just for play..thanks
Old 08-16-2004, 12:49 PM
tastyklair's Avatar
tastyklair
tastyklair is offline
As has been said here many times, dollar for dollar you will be able to get more out of the 400 compared to what the hassle and price of the 460 swap will set you back. Also the 460 weighs more. If you had both engines side by side and there was no difference in installation between the two then the 460 would be a more attractive option, but thats not the case. Besides its nice to tell someone that remarks how well your truck runs, that it's a 400. They don't expect that.
Old 08-16-2004, 08:57 PM
coolmint94's Avatar
coolmint94
coolmint94 is offline
What are you going to be using the motor for??
With Cleveland heads, are they the 2v or 4v?
You will probly get more power out of a 429 for a little less but as Tastyklair said, just having a motor that is often overlooked is always a cool thing to do.
Old 08-18-2004, 02:29 PM
mark a.'s Avatar
mark a.
mark a. is offline
There would be no reason to build a 429 when 460 cranks are a dime a dozen. Cubic inches always prevail.
