2002 Explorer Sport Water Leak
Old 05-18-2002, 10:31 PM
Shep927's Avatar
Shep927
Shep927 is offline
I've got a 3 month old 2002 Explorer Sport. Both rear push out windows have leaked when it rains since I purchased the vehicle. Local Ford garage replaced both window gaskets 3 weeks ago. Passenger side window still leaks heavily, to the point that the entire rear carpet is under water. Has anyone else experienced this problem?
Old 05-19-2002, 09:05 PM
spoon059's Avatar
spoon059
spoon059 is offline
I've got a 2001 sport that leaks. Ford thinks it is the rear tailgate window seal leaking. It will be replaced tomorrow night, I suggest you have Ford check that. The cargo area carpet gets soaked through, but it's never so much that you can tell the whole carpet is "under water"
Old 07-01-2002, 07:38 AM
sport01's Avatar
sport01
sport01 is offline
I've got a 2001 SPort and have yet to see it leak. Sorry I can't help....
Old 07-01-2002, 07:52 AM
Shep927's Avatar
Shep927
Shep927 is offline
Thanks for the info. Did finally get the problem fixed. Turns out that the roof rails were not properly installed. Water was getting under the gasket and leaking down through the bolt hole in the roof. The water was collecting by the rear push out windows, so naturally everyone assumed that the window gaskets were the culprit.
Old 07-01-2002, 08:38 AM
CobraXP's Avatar
CobraXP
CobraXP is offline
hippyguy03
09-28-2016 07:12 AM
cecilj
11-13-2015 10:52 PM
FLRob
02-12-2014 11:37 PM
JeepnAggie
2004 - 2008 F150
47
01-06-2011 08:01 PM
wantford
02-28-2010 02:38 PM
Quick Reply: 2002 Explorer Sport Water Leak
