Mr Doofus Wants to Know - Metallic vs Metal Flake
My apologies for a completely stupid question but what qualifies as metal flake paint? Is a color called 'metallic gray' a metal flake paint or is it really a metallic - one of those real shiny, metal looking surfaces? The surface in question is '92 Taurus I would like to repaint. The original factory dark gray paint has very subtle highlights in it and I can't tell if this is a metal flake or not. A body shop I took it to called it a metallic gray. Can anyone shed light on this for me? Are there gradations of metal flake finishes? (fine to coarse) The only metal flake finishes I have been around were the ones from the '70's that had these big, huge flakes embedded in the finish.
If this is a fine metal flake are there any special precautions for spraying using a conventional gun, not HVLP? Thanks!
Its kind of subjective. I always called a paint metal flake if I could distinguish between each individual flake. If not, I called it metallic. I have sprayed both with a conventional gun, with an agitator cup, of course. As far as precautions, follow the recommendations of the paint manufacturer with regard to breathing protection, etc.
Metal flake has very obvous flakes of metal. There are no car manufacturers who put metal flake on a production car because there are too many steps involved in applying it and there is a heavy duty sanding needed before the final clear coats. Would cost a mint at the factory. At least I am aware of no one who puts it out on a stock vehicle. You can stand back and see metal flake sparkle from a distance. You definitely have metallic.
speakerfritz
6.4L Power Stroke Diesel
01-02-2016 08:20 PM
rageoda
1983 - 2012 Ranger & B-Series
09-01-2010 01:19 AM
DAI532
09-25-2009 06:48 AM
