Alternator Connector Melted
After a huge rain storm here, the connector that plugs into the alternator melted, I assume the water and electric didnt mix well.. The alternator itself looks good.
1> is there a way to test the alternator without this connector plug?
2> can i buy the entire connector/wiring and just replace the one that is damaged??
thx..
thx..
fordfuelinjection.com Ryan can get you set up with a replacement wiring harness.
Take it to an a shop that rewinds. They can check it out for you.
Easiest fix is to either like the guy said before just go to your local auto parts store and get a new connection or just go to a junk yard and just clip the connection off with a good 6 inches of wire with it and just connected it to your vehicles original altenator wire.
Problem is solved
Problem is solved
BBslider001
10-21-2016 10:06 AM
Larry horne
11-14-2008 10:02 AM
1990Fordf150v8
15
07-08-2004 10:14 AM
