1962 Ford F-602 Timing
Does anyone know the timing of a "Q" engine. I think it is a engine; or if not, do you know if it is covered in the sevice manual? That is to ask, is it worth my spending $75 to buy a manual only to find that it either is not in the manual or that it is something that someone here can tell me? Tks.
I'm going to guess you have a 292. A V-8 where the driver side exhaust comes out the front and crosses to the passenger side manifold?
I'm going to guess again. Try 6 degrees btdc. Regular fuel 289's & FE's were at 6 degrees, so I'm guessing Ford liked that number. You might be able to run up to 10, but start at 6 and see how it runs.
Still have points? .16 I think. Am I right? Is my memory still there?
Better minds may chime in.
ID that motor and try the motor specific threads if you have no luck.
Hi Sam,
Engine code "Q" would be the 477 Super duty V-8 engine.
According to my '59 Truck shop manual...............
"Initial Ignition Timing (B.T.D.C.)"
"All HD and SD V-8 (302,332,401,477,534)
With regular fuel of 85-88 octane..........................................4 Deg.
With regular fuel of 88-90 octane..........................................6 Deg.
With regular fuel of 90-92 octane..........................................8 Deg.
With regular fuel of 92 octane or more, or premium fuel............10 Deg."
I hope this helps.
I hope this helps.
stloupster
50
07-25-2022 03:13 AM
DedmonDuppy
13
09-25-2019 02:11 PM
