I need a diagram of the fuel supply
#46
I uploaded some pictures that I took of the mod that I came up with after all this.
http://client.webshots.com/album/170683790Tiydwc
#47
#48
#49
Kwik,
So now that it's been a month or so since you converted your 99's fuel system basically to that of a 97, can you give us a follow-up report on things like: whether you are maintaining adaquate fuel rail pressure, whether you feel you have completely eliminated fuel air entrainment, and if there are any further economy issues addressed? Are you concerned about your restrictor orifice eroding and reducing the rail pressure?
Have you considered hard-plumbing (maybe with stainless) the right rear fuel supply under the exhaust side of the turbine to eliminate the need for that heat shield?
SpringerPop
SpringerPop
#50
Springer
I have benn running hydrolic hose for about hose for about 6 mounts whit out any promlem and no heat sheild. My truck is only running the new feeds with the left running front to back and it has helped a lot with the noise the truck made. the way ford has it set up tends to strave the 6 8 firing event amd it worse if you have a chip. it dosn't take much to figure out that the ent of the rail has two injectors that fire in order wil tend to have air in the end of the rail and it make the # 8 firing lean
#51
Springer
I have been running hydrolic hose for about hose for about 6 mounts with out any promlem and no heat sheild. My truck is only running the new feeds with the left running front to back and it has helped a lot with the noise the truck made. the way ford has it set up tends to strave the 6 8 firing event and it worse if you have a chip. it dosn't take much to figure out that the ent of the rail has two injectors that fire in order wil tend to have air in the end of the rail and it make the # 8 firing lean
#52
Originally Posted by SpringerDad
Kwik,
SpringerPop
SpringerPop
I never gave any thought to the oriface eroding away. It's made of brass right now. Honestly I don't know how it will hold up. If it fails I'll have to find a machine shop to drill out a piece of stainless steel.
Fuel economy has ended up being about 10-11 mpg pulling the trailer. Total GVW 23000lb aproximatly maintaining 65-69 mpg. 4.88 rear axle and six speed stick. Any faster than that and the engine starts to work so hard just pushing through the atmoshere that the clutch fan comes on and stays on even on a straight and level road. Never mind a hill. So I keep the speed down.
I'll never hard plumb to eliminate the heat shield. It's nicely shielded and not chafing against anything there.
A final note on the fuel pressure thought in this post: I just purchased the adjustable fuel pressure regulater from Diesel innovations along with thier Swisher wheel. On a free saturday I plan on installing the two. When I do that job I also want to put in a tee on the fuel system so I can measure the pressure. I will then be able to provide some hard figures for all these questions. I will post them for all to read here. Give me a month or two. (busy times)
#55
January 2005 update
Finally got around to installing the fuel pressure regulator from DI. I was dissapointed to learn that my fuel pump is wearing out: it can only make 65 psi max. I put the smallest shim into the regulator and the pressure went up a little to about 59. (Hmmm, want a little more than that.) Put the next size shim in: 61. (Want more) Put the fattest one in: 65 psi and the pressure is so uneven that the needle on the guage is wobbling violently from 40-80 psi. If this pump is anything like the Bosch units that I deal with every day it should be well over 100 psi with that shim in there. I drop back down to the medium sized shim and the pressure stays the same, just the pressure spikes go away. So I guess I know what the next purchase is going to be for the truck.
#56
#57
majer fuel leak
if you have the link on fuel lines could i get it from you? my email is tonygross2004@hotmail.com .i have a major fuel leak at the back of the motor its a 2001 f250 7.3. the motor valley is dry. and it takes 5 min before it starts to drip around the passenger side of the block and into the tork cover and finally drip the fuel out of the tork drain hole. by reading your thread it sounds like their is a plug their. but where? can you give me some insight on this. i posted a new thread about a bad fuel leak in the forums.
#58
#60
on
no need to pull the down pipe..or i didnt need to for them oring or putting in the regulated return line..if the valley is dry up top..get under the truck and look up and see if everything is wet at the back of the block where the down pipe is....if it is you will need a new oring sleeve to stop it..when you put the oring on the line..hand tighten the nut till it hits the 0ring..then with a wrench give the nut a 1/2 turn..turn key on and see if it leeks..if it does..give it another 1/2 turn...if you go tight on the nut..it spoils the oring and you will need to start over..
here are the sleeves.keep in mind when you order..there are 4 of these on your truck..
Replacement O-rings for Diesel Engines
