AOD TV Rod adjustment help - Ford Truck Enthusiasts Forums
Old 07-12-2004, 11:25 PM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
Does anyone know how to adjust the early AOD TV Rod linkage shown here. Any help is really appreciated.
Old 07-13-2004, 03:40 AM
drewcoolness99's Avatar
drewcoolness99 drewcoolness99 is offline
drewcoolness99 is starting off with a positive reputation.
have a better pic? I'll see what i can find on it and get back to you.
Old 07-13-2004, 10:25 AM
51dueller's Avatar
There is a little set screw at the top of where rod connects to the carb and where the rod connects to the tranny lever threads up or down.
Old 07-14-2004, 07:04 PM
51dueller's Avatar
Bump. anyone?
Old 07-14-2004, 07:27 PM
on the mount by the carb there is a lockin tab that you pull up and pull the cable through a little. umm here lemme know if this works
Old 07-15-2004, 01:19 PM
51dueller's Avatar
I don't have a cable but a solid metal rod. I guess they must have only used the rod on the CFI throttle body carburators. I modified my Motorcraft 2150 throttle linkage to add the AOD linkage of the junked CFI carb that was on the engine when I got it. I got the TV Rod off an '84-85 Ford Thunderbird and the tranny arm off an '83 Ford LTD AOD. I have mounted these on my '90 Ford Crown Victoria AOD. I think the TV Rod is set up correctly but I want to make sure. I think the set screw at the carb linkage is to set the tranny's shift pressure. Thanks for the help though.
Old 07-16-2004, 05:56 AM
dbhr's Avatar
dbhr dbhr is offline
dbhr is starting off with a positive reputation.
You have to install a pressure gauge on the tv port on the passenger side of the trans,and adjust the pressure until you get 33 psi on the gauge. If i remember right it is the middle port, hope this helps.
Old 07-16-2004, 03:57 PM
mt54's Avatar
mt54 mt54 is offline
mt54 is gaining momentum as a positive member of FTE.
Hey, I could be wrong, but isn't the rod for the kick down ??? I thought the TV came off the other side of the trany..
Mike
Old 07-16-2004, 04:05 PM
mt54's Avatar
I have a 80 aod out of a thunderbird, never seen it all togather, so I not sure how it hooks up, I'v been lookin for info on this myself, My trany just has the lever on the trany under the shift lever,the other side has a cap and labeled TV, Do I need a cable or just the rod ??
Mike
Old 07-16-2004, 11:54 PM
51dueller's Avatar
Is the second lever a straight arm that points to the front of the tranny or is it bent like a backwards C. The backwords C used the TV cable and the straight arm used the TV Rod. I car I took the TV Rod off was a complete original '84-85 Thunderbird 302 with CFI and an AOD tranny since the gear shifter said P R N OD D 1. I know that the C3, C4 and C-5 trannys in the mustangs used kickdown rods but they had a different way of bolting to the carb.
Old 07-17-2004, 02:48 AM
Quote:
the tv linkage on my truck has a straight arm but has a cable though.
Old 07-17-2004, 03:07 PM
mt54's Avatar
Mine appears to be striaght pointing to the front.. I havn't picked a carb yet,will this need to be considered, due to the cable or rod ? or is it just a matter of the right linkage ?? When you say adjust the TV psi. How is that done ? At a spec.RPM ? Would this adjustment change on the trany if you use the same t.converter and all, Or is adjusting this psi. only somthing needed done after a rebuild of the trany ? I know thats alot of ?s but I'm just trying to learn, any info would be great thanks!!
Mike
Old 07-19-2004, 01:50 PM
mt54's Avatar
Any more info on the TV cable/rod ??
Mike
Old 07-19-2004, 03:24 PM
alcan60283's Avatar
alcan60283 alcan60283 is offline
alcan60283 is starting off with a positive reputation.
MY haynes manual has the procedure to adjust the TV lever. It seems like nobody has ever seen these before for some reason. ITs a very simple process. As soon as i get home (1-2 hours) i will post how to do it correctly.
Old 07-19-2004, 03:49 PM
Redone Redone is offline
Redone is starting off with a positive reputation.
Looks like you and I dueller have are in the same boat. I'm having trouble with my TV rod and it's almost impossible to find anyone who has or had the TV Rod and not the TV cable. They are adjusted differently.
I sure would like to get this problem solved, quickly!
HOW TO: Changing Carburetors and Making it Work with an AOD LARIAT 85 '80-'86 HOWTO's 21 11-26-2016 12:09 PM
AOD TV cable adjusment issues Montync Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 11-01-2016 10:59 PM
tv rod bh867 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-28-2016 10:57 PM
85 E-150 AOD TV rod adjustment annaleigh 1968-2013 Full Size Vans 2 10-31-2014 07:50 PM
AOD TV Cable dasoundman Clutch, Transmission, Differential, Axle & Transfer Case 2 05-13-2011 09:31 AM
Tags
1989, 1997, 85, adjustment, adjustments, adustment, aod, aode, cable, carbed, f150, ford, lever, rod, thunderbird, transmission, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
