AOD TV Rod adjustment help
https://www.ford-trucks.com/lc/lc.ph...3d800a837f.jsp There u go guys. Its about halfway down that page. Its the throttle valve adjustment section. The guide for the cable is right under it. Hope you find what you need.
im having problems with my kickdown rod too.but I drove mine with it out of whack.do anyonr think I burned my overdrive up?
Just bumping this thread...the link above is dead, can anyone point me to that info or give advice on tv rod info and adjustment???
Vehicle I have is a 84 Club Wagon XL with 302 and early AOD tranny...door sticker says vin code T under the trans type...which led me to a a4ld BUT after looking at tranny it's an AOD 14 bolt square pan
Problem is trans will not shift out of 1st...1st and reverse are strong, no slippage...van sat for 6mos or more...have heard to clean governor and drop pan and make sure everything is hooked up...
Any help appreciated
LARIAT 85
'80-'86 HOWTO's
28
07-07-2022 03:50 PM
81flareside
29
02-08-2018 02:56 AM
83f150xlt
01-31-2017 06:30 PM
Montync
11-01-2016 09:59 PM
1989, 1997, 85, adjustment, adjustments, adustment, aod, aode, cable, carbed, f150, ford, lever, rod, thunderbird, transmission, tv
