Dyno Day!
Dyno Day!
Project Fordy went on the dyno today.
Started out with 207 RWHP, we got it up to 235RWHP and 276 ft/lbs.
Broke the distributor gear because apparently a steel one was on there when a bronze one should have been. Not really my fault being the newbie and all. I just got the distributor from the engine builder and it had a gear on it, so I just put it in not knowing about using proper gears or not. Live and learn, for next time.
It has a bit of work done to it, not much...
These are Mustang Dyno numbers too, so they are a little lower than Dynojet numbers. I'm going to ask them to do a couple runs with Dynojet parameters.
Also, this is only on 8.6:1 compression.
Next step will be a blower if anything, just going to have to save the pennies.
Got around to capturing the video, here's a couple runs.
http://www.projectfordy.com/vids/dynoday.wmv
