1978 - 1996 Big Bronco
Shifting hard
Old 07-12-2004, 05:50 PM
dyarumian's Avatar
dyarumian
dyarumian is offline
Shifting hard
I have a 96 5.0 5 speed, with a new/ used tranny as of january. It doesnt shift as smooth as it used to and is hard to get in gear when stopped (I sometimes have to pump the clutch). Think it just needs a fluid change? (It might have some water in it or something?) What kind of fluid should i use? Thanks for the help
Old 07-12-2004, 07:28 PM
bronco5.8's Avatar
bronco5.8
bronco5.8 is offline
I assume you had the clutch replaced too. If so then you may have to bleed the hydraulic system and the fluid should be DOT 3. This should say it somewhere on the fill cap.
Warr
Old 07-12-2004, 09:17 PM
Jdenninger's Avatar
Jdenninger
Jdenninger is offline
i agree with bronco5.8. bleed the clutch. sounds like air in the system. that or your clutch is going if it wasn't replaced when the tranny was.
Old 07-12-2004, 10:16 PM
dyarumian's Avatar
dyarumian
OK ill try bleeding the clutch, tomorrow. The last time i did it it was 10 below, might be a little easier this time
ffdevin
09-16-2016 11:53 AM
greentruck72
04-30-2016 01:23 AM
fordka
10-20-2015 08:37 PM
renoduckman
Oil & Lubrication
09-03-2014 12:57 PM
Mater03
08-11-2014 11:39 PM
Quick Reply: Shifting hard
