1997 explorer A/C problem
Help needed,
I have for some time had a problem with the A/C control blowing hot air however, when switched to Max blow cold air. Recently the Max has started not blowing cold air but cool air. This had happened a time earlier and I was told it was a fuse which for awhile fixed the problem with the A/C dial so that it produced cold air however, then stopped again. Any help before taking this to a shop would be great... any suggestions . . . .
thanks
chad
thanks
chad
Sounds like you temp control door is not switching like it should I ran into this on my 98 explorer the door is controlled by an electric motor located behind the glove box and is hel down by 3 torx head screws. Remove the torx screws and remove the motor then ge a small mirror and look down into the recess that the motor fits in and I will bet the plastic is cracked and not letting it switch from hot to cold.
rogerf100
10-19-2011 06:54 PM
