97 Explorer Brake Lights not working - Ford Truck Enthusiasts Forums
Old 07-12-2004, 01:52 PM
sjwgator sjwgator is offline
sjwgator is starting off with a positive reputation.
I have a 1997 Ford Explorer Limited and the brake lights stopped working on me last week. I tried replacing the bulbs, and that still didn't work. I opened up the fuse box, and the brake light fuse seems to be in tact. Can anyone point me in the right direction to taking a look at the wiring to my brake lights? Or where the connection from my brake pedal to my brake lights is? I believe it's just a connection problem, but it could be a short in the wiring. Any thoughts? Any help is greatly appreciated.
Thanks,
Steven
Old 07-12-2004, 02:26 PM
LV Dan LV Dan is offline
LV Dan is starting off with a positive reputation.
Check the brake switch located near the brake pedal under the dash. Put an ohm meter or continuity checker on the terminals and depress the brakes; it should short out when pressed.
I have had to replace these switches before and have even done an emergency repair by opening them up and cleaning the contacts. A small amount of corrosion/carbon forms each time the brake is released.
Old 07-12-2004, 02:56 PM
Top Jimmy's Avatar
Top Jimmy Top Jimmy is offline
Top Jimmy is starting off with a positive reputation.
You might take a look at this thread...
http://www.ford-trucks.com/forums/sh...d.php?t=228333
Or just doing a search for brake lights in this forum.
Best of luck,
Top Jimmy
Old 07-13-2004, 02:22 PM
Thanks, Top Jimmy; great thread. I had no idea about the Lights Out Module; and believe it or not, I just discovered my brake lights didn't work when I hooked up my trailer. My brake lights are working fine now, but I suspect they will go intermittent on me again. However, I didn't get any indicator that the bulbs were out so I am still suspect of the actual brake switch. But no one on your suggested thread said anything about getting an indicator warning, so I will get the DMM out and start monitoring!
Old 08-19-2004, 03:00 PM
Top Jimmy's Avatar
Your Welcome Dan
I have read some of your other post and you seem pretty savey when it comes to this type of thing. As an update, I have not yet been able to solve my brake light problem dispite checking the fuse and changing out the switch at the pedal. It appears that that any model without a message center does not have a LOM (see my latest post here http://www.ford-trucks.com/forums/sh...d.php?t=170121 )
So, presently I am still stuck with only the third brake lamp working. In this thread http://www.ford-trucks.com/forums/sh...3&page=2&pp=25 one user tells of the Ford House finding a short in the rear LH qtr panel as the problem and another related that his was caused by a short in the steering column near the hazzard switch. While I do have some reason to suspect an short in the steering column, I am not convinced that that could affect the brake lights.
If you have any suggestions I would greatly appreciate it.
Thanks,
Jimmy
Old 08-20-2004, 03:12 PM
Jimmy:
Without the LOM, The High Mount Stop Lamp and the lower LH & RH Stop Lamps are all fed power directly from the Brake On/Off Switch and does not go through the Multifunction Switch. There is one point where the power from the Brake Switch is split and goes to about 10 different places including all the stop lamps. The Hazard Lights feed the LH & RH Rear Turn Signal Lamps and not the brake lamps.
The High Mount Stop Lamp has a seperate ground. The LH and RH Stop Lamps use a common ground along with the LH and RH Rear Turn Signal Lamps. Do the RH & LH Rear Park Lamps illuminate with the headlights on? If so, it is not the ground wire as they share the same wire/ground.
Do you have a Remore Anti-Theft Personality Module? If so, the lower RH & LH Rear Stop Lamps have a common wire with this module. Find that module and see if you are getting 12Volts on pin 26 of that module with the brake pedal depressed.
Please don't take offense to this, Top Jmmy, but I assume you have checked the lamps and they have continutity (must be checked with an ohm meter because sometimes you can't see the break) and that the lamps have two fillaments, one for brake and one for park lights.
Do you have access to a good Digital Multi-Meter (DMM)?
Old 09-03-2004, 03:03 PM
Ford must have made changes to the Lights Out Module somewhere in the late 90's because my brake lights do not go through this module. However, there is one for the headlamps that is interconnected with the Autolamp and Day/Night Rear View Mirror. So it cannot be the L.O.M. that is my problem.
Old 09-07-2004, 08:58 AM
Top Jimmy's Avatar
LV Dan,
Thanks for all of the good information! I finally found (took) time this Holiday weekend to get after this problem. While I am not sure that I located exactally the problem, I do have brakelights that work again. I believe that there was a grounding problem with the trailer light adapter which had ridden unused and uncovered for years under the rear bumper. After checking all wires, connections, etc. and giving that plug good cleaning, I was back in business.
Thanks to you and all the others for the help and suggestions,
TJ
Brake lights...E-Z wiring hwyhogg 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 12-08-2014 08:15 PM
No Brake lights or Hazards oldblue89 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 02-03-2013 09:19 PM
Trailer running lights John Puig 1999 to 2016 Super Duty 9 12-07-2010 05:20 PM
98 Explorer Sport Trailer wiring problem jtexas Explorer, Sport Trac, Mountaineer & Aviator 2 11-15-2010 01:28 PM
electrical lighting problems please help Ian Poush Explorer, Sport Trac, Mountaineer & Aviator 3 08-16-2002 10:48 PM
Tags
1997, 2000, 96, brake, dont, explorer, ford, fuse, light, lights, lower, sport, stop, work, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
